amend my script
amend my script
Message 1 of 13
amend my script
(if (and a b)
(progn
(if (assoc a lst)
(setq lst (subst (cons a (+ b (cdr (assoc a lst)))) (assoc a lst) lst))
(setq lst (cons (cons a b) lst))
);; if
(setq a nil b nil)
);; progn
);; if
When I use the above code in my script I am getting the values in the below format
(("PART01" . 6.0)("PART02" . 4.0)("PART03" . 3.5))
But I am looking for a way to add quotations to all second items aswell inside the list like below:
(("PART01" . "6.0")("PART02" . "4.0")("PART03" . "3.5"))
Replies (12)
Message 2 of 13
hak_vz
Convert second part to string using function RTOS
(rtos (+ b (cdr (assoc a lst))) 2 1)
and
(rtos b 2 1)
Miljenko Hatlak
Message 3 of 13
(if (and a b)
(progn
(if (assoc a lst)
(setq lst (subst (cons a (rtos (+ b (cdr (assoc a lst)))2 1)) (assoc a lst) lst))
(setq lst (cons (cons a (rtos b 2 1)) lst))
(setq a nil b nil)
Thank you for your reply Hak. I am unsure where to copy your code. When I tried amending your code like above format it gives me an error. Please help me if I copied incorrectly in the code
Message 4 of 13
hak_vz
Update your script and sample data. It is hard to work on a part of the script without sample data to test.
Miljenko Hatlak
Message 5 of 13
(progn
(setq s1 (ssget "_x"(list '(0 . "INSERT")'(2 . "SOR_1,`**")'(66 . 1)(cons 410 (getvar 'CTAB)))))
(repeat
(setq i (sslength s1))
(setq hnd (ssname s1 (setq i (1- i))))
(setq ent (entget hnd))
(setq attlst nil)
(setq obj (vlax-ename->vla-object hnd))
(setq attlst (vlax-invoke obj 'GetAttributes));; setq
(foreach att attlst
(cond ((and (= (strcase (vla-get-TagString att)) "PART_1")
(/= (vla-get-TextString att) ""))
(setq a (vla-get-TextString att))
((and (= (strcase (vla-get-TagString att)) "Quantity")
(setq b (atof (vla-get-TextString att)))
);; cond
);; foreach
(if (and a b)
(progn
(if (assoc a lst)
);; if
(setq a nil b nil)
);; progn
);; if
);; repeat
(if lst
(progn
(setq lst (vl-sort lst (function (lambda (a b) (< (car a) (car b))))))
(setq i 0)
(setq tmp_lst (reverse lst))
(setq sel_lst (cons '("PART NAME." "Quantity") sel_lst))
(setq sel_lst (append sel_lst lst))
(gc:WriteExcel file nil nil sel_lst)
); progn
Here is the part of my code. I am just trying to export the sum of attribute values into existing excel. I tried in so many ways but I am unable to do it. I am just a basic scripter in lisp. If possible can you have a quick look in my code and what's wrong to populate the list in excel. With my code I can extract the values of Part name but not the sum of quantity in my excel. Thanks in advance
Message 6 of 13
hak_vz
Script is written OK,  at least this part. You have
(setq a (vla-get-TextString att))  -> string
(setq b (atof (vla-get-TextString att))) -> real  to enable later calculation
(if (and a b)
(progn (if (assoc a lst)  -> what is in lst ?
Miljenko Hatlak
Message 7 of 13
(if (and a b)
List of attribute values from each entities. I copy this part from another program which gives me to calculate the sum of attribute values based on the attribute tag for each part names .
Message 8 of 13
hak_vz
here is error
You have b converted to real but a is a text
it should be
(+ b (atof(cdr (assoc a lst))))
Miljenko Hatlak
Message 9 of 13
No luck Hak.. I tried to replace my code with "(+ b (atof(cdr (assoc a lst)))" but still not working
Message 10 of 13
hak_vz
Sorry, will try to look on later.
Miljenko Hatlak
Message 11 of 13
Okay sure, thank you
Message 12 of 13
Sea-Haven
Posted at cadtutor as well.
Message 13 of 13
Hi yes, I posted this query in other forum aswell. Iam awaiting for the correct code for my script. I have searched so many forums for this type script and unable to find the correct code. So I have posted in forums, someone can help me to resolve my coding issue.
