lisp - check edit window
Wheelie22
Wheelie22
We had ACAD 2021 installed last week (from ACAD 2017), and now I see Vlide has changed.
I used to get a variable check with the command : check edit window
Is this gone or is there a option for this ?
  • Lisp
To use Vlide just change the variable LISPSYS > 0.
hak_vz
Check this link about enabling vlide in Autocad 2021.
There is new development platform Visual Studio Code that is set to be default editor.
To enable vlide you have to change system variable LISPSYS to 0.
You can use System variable monitor
or run in command line
(setvar 'LISPSYS 0)
Miljenko Hatlak
rkmcswain
@Wheelie22 - it's still there. Or use Ctrl+Atl+C
R.K. McSwain     | CADpanacea | on twitter
Wheelie22
Almost, here is the <build Output> check in 2017 :
And here the same file in 2021 :
No more Global variables ?
rkmcswain
@Wheelie22 - in the VLIDE, go to Tools > Environment Options > General Options > Diagnostic tab
Make sure all of those are checked ON.
Wheelie22
Great, thanks all.
