Volume calculation
Volume calculation
k005
Advisor Advisor
Message 1 of 27
Volume calculation
k005
Uzunluk : 25x45x989
Uzunluk : 30x45x1160
Uzunluk : 30x45x315
Uzunluk : 325
Uzunluk : 450
Hello friends
From the data in this section;
a- How can I divide by 100 and multiply the ones with x in them and add the results?
b- How can I add the ones that do not have an x in them? and divide 100
desired result
a... Total Volume: 3.103 m³
b... Total Length : 7.75 m
Replies (26)
Message 2 of 27
ronjonp
Assuming you're selecting text...
(defun c:foo (/ l s str v x)
  ;; RJP » 2021-08-12
  (cond	((setq s (ssget '((0 . "text"))))
	 (setq l 0 v 0)
	 (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (if (vl-string-search "x" (setq str (cdr (assoc 1 (entget e)))))
	     (setq v (+	v
			(apply '*
			       (mapcar '(lambda (x) (/ x 100.))
				       (read (strcat "(" (vl-string-translate "x" " " str) ")"))
	     (setq l (+ l (atof str)))
  (princ (strcat "\nVolume: " (vl-princ-to-string v)))
  (princ (strcat "\nLength: " (vl-princ-to-string l)))
  (princ)
Message 3 of 27
Kent1Cooper
EDIT:  Great minds think alike, even down to the letter used in the argument in the (lambda) function.  I was beat to the punch, but here anyway....
One way to do the the numerical parts of extracting information in meters from centimeter inputs, in the first 'a' and 'b':
(setq str "25x45x989")
[extracted from first item], then:
(apply '* (mapcar '(lambda (x) (/ x 100.0)) (read (strcat "(" (vl-string-translate "x" " " str) ")"))))
returns the volume of that item:
1.11263
If str is set to just "325", extracted in the same way from the fourth item, the same code returns 3.25.
Later I may try putting the rest of it together....
But I wonder:  If you are selecting Text objects, are they only the numbers [with or without x's], or do they include the  Uzunluk :  part that would need to be stripped off?
Kent Cooper, AIA
Message 4 of 27
k005
@ronjonp
Results and plugin:
* it processes when I separate the text. But for now, there is no such distinction.
* Add : Let it select the texts in the "KirisuzunlukYazi" layer only..
Thanks.
Message 5 of 27
k005
@Kent1Cooper
There is no part to remove... just exactly as I wrote it.
I'm also wondering;
Did you write this part for me or is it general?
Message 6 of 27
ronjonp
@k005 wrote:
@ronjonp
Results and plugin:
Thanks.
For the layer filter change this:
to this:
(setq s (ssget '((0 . "text") (8 . "KirisuzunlukYazi"))))
Message 7 of 27
k005
@ronjonp
Ok I added the layer part. . All right, making a choice.
but :
I am getting the following error: ;
error: bad argument type: numberp: UZUNLUK
Message 8 of 27
ronjonp
@k005 wrote:
@ronjonp
but :
Try this mod:
  ;; RJP » 2021-08-12
  (cond	((setq s (ssget '((0 . "text") (1 . "*#*") (8 . "KirisuzunlukYazi"))))
	 (setq l 0 v 0)
	   (while (null (wcmatch (substr str 1 1) "#")) (setq str (substr str 2)))
	   (if (vl-string-search "x" str)
	     (setq v (+	v
			(apply '*
  (princ)
Message 9 of 27
k005
@ronjonp
; error: bad argument type: stringp <Selection set: 3e>
Message 10 of 27
ronjonp
Try the code above again .. had a typo.
Message 11 of 27
Kent1Cooper
I'm also wondering;
Exactly as you wrote it is not entirely clear.  Does each line at the beginning of Message 1 represent the content of a separate Text object, and the User would select those Text objects?  If so, it would be necessary to remove the  Uzunluk :  part from the contents of each string, to leave only the relevant numerical parts.  If selected Text objects would actually be just the numerical parts, without the  Uzunluk :  part, then no, there would be nothing to remove.  But since you didn't specify the nature of the "data," other possibilities exist:  they could be in a spreadsheet file, or a table, or Attributes in Blocks, or....
The "great minds" statement is about the fact that both @ronjonp and I, independently, came up with exactly the same way of calculating the volume in cubic meters from a text string of lengths in centimeters with x's between them.  There are certainly other ways to structure that calculation, so it was interesting to me that ours were identical.
Kent Cooper, AIA
Message 12 of 27
k005
there is one more mistake. cannot choose.
Message 13 of 27
ronjonp
Post your sample drawing.
* And try the code above again.
Message 14 of 27
k005
attaching the file.
Message 15 of 27
k005
@ronjonp
Ok. Thank you very much, 🤗
Message 16 of 27
Kent1Cooper
So they are separate Text objects, including the prefix.  If that prefix is always exactly the same, then (substr TextContent 11) will get just the numerical part at the end.  If it might vary, it could be stripped off in other ways.
Kent Cooper, AIA
Message 17 of 27
ronjonp
@k005 wrote:
@ronjonp
Glad to help .. here's a mod that filters by text string so we can chop off the prefix then do the calcs.
  ;; RJP » 2021-08-12
  (cond	((setq s (ssget '((0 . "text") (1 . "Uzunluk : *"))))
	 (setq l 0 v 0)
	   (setq str (substr (cdr (assoc 1 (entget e))) 11))
	     (setq v (+	v
			(apply '*
  (princ)
Message 18 of 27
k005
@ronjonp
It was even more beautiful. Thank you. I can easily change this. 🤗  OK.
Message 19 of 27
hak_vz
@k005  I'm a bit late to the show, but anyway.
(defun c:moo (/ ss i l a v ss e string_to_list *error*)
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
	(defun string_to_list ( str del / pos )
		(if (setq pos (vl-string-search del str))
			(cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
			(list str)
	(princ "\nSelect length/area/volume text:")
	(setq ss (ssget '((0 . "TEXT")(8 . "KirisuzunlukYazi"))))
	(setq i -1 l 0.0 a 0.0 v 0.0)
	(while (< (setq i (1+ i)) (sslength ss))
		(setq e (cdr (assoc 1 (entget(ssname ss i)))))
		(cond
			((and(vl-string-position (ascii "x") e))(setq e (string_to_list (substr  e (+ (strlen "Uzunluk :")2)) "x")))
			(T (setq e (list(substr  e (+ (strlen "Uzunluk :")2)))))
		(cond
			((= (length e) 1) (setq l (+ l (apply '* (mapcar '* (mapcar 'atof e))))))
			((= (length e) 2) (setq a (+ a (apply '* (mapcar '* (mapcar 'atof e))))))
			((= (length e) 3) (setq v (+ v (apply '* (mapcar '* (mapcar 'atof e))))))
	(cond ((> l 0) (princ (strcat "\nTotal length = " (rtos (* 1e-2 l) 2 4) " m"))))
	(cond ((> a 0) (princ (strcat "\nTotal area = " (rtos (* 1e-4 a) 2 4) " m2"))))
	(cond ((> v 0) (princ (strcat "\nTotal volume = " (rtos (* 1e-6 v) 2 4) " m3"))))
	(princ)
 Calculates total length, area and volume.
Miljenko Hatlak
Message 20 of 27
k005
@hak_vz
Yes. This is very nice work.
Thank you very much. I save it in my archive. 🤗
