Volume calculation
Volume calculation
k005
Advisor Advisor
Message 1 of 27
Volume calculation
k005
Uzunluk : 25x45x989
Uzunluk : 30x45x1160
Uzunluk : 30x45x315
Uzunluk : 325
Uzunluk : 450
Hello friends
From the data in this section;
a- How can I divide by 100 and multiply the ones with x in them and add the results?
b- How can I add the ones that do not have an x in them? and divide 100
desired result
a... Total Volume: 3.103 m³
b... Total Length : 7.75 m
Replies (26)
Message 21 of 27
k005
@ronjonp
Adding:
Can we draw little yellow dots on points P1 and P2?
dot size : textsize
Message 22 of 27
Kent1Cooper
[Are you in the right topic?  I don't see any P1 and P2 here.  Should you be asking over >here<?]
Kent Cooper, AIA
Message 23 of 27
k005
@Kent1Cooper
Sorry... I posted in the wrong topic.
Yes, the link you gave... I am writing it again in the right part. 😔
Message 24 of 27
ronjonp
@k005 wrote:
@Kent1Cooper
Maybe you can implement this .. sure we could do this with COMMAND, but where's the fun in that 🙂
(defun _makedot	(p l s c)
  (entmake (list '(0 . "LWPOLYLINE")
		 '(100 . "AcDbEntity")
		 '(67 . 0)
		 (cons 8 l)
		 (cons 62 c)
		 '(100 . "AcDbPolyline")
		 '(90 . 2)
		 '(70 . 1)
		 (cons 43 (/ s 2.))
		 (cons 10 (mapcar '- p (list (/ s 4.) 0)))
		 '(42 . 1)
		 (cons 10 (mapcar '+ p (list (/ s 4.) 0)))
		 '(42 . 1)
  (princ)
;; Point, layer, size, color
(_makedot (getpoint) "DotLayer" 5 2)
Message 25 of 27
k005
@ronjonp
I'm trying right now... 🙂
Now how should I combine this code with the other lisp code?
Message 26 of 27
Kent1Cooper
[Take it over to the other topic.  If you get to a good solution here, no one with the same kind of need who finds the other topic will have any way to know it's solved here.]
Kent Cooper, AIA
Message 27 of 27
k005
@Kent1Cooper
OK
