Filter nested list if item exists
Browning_Zed
Browning_Zed
Hi All,
I again had a need to process the list. There was a need to filter the list if a certain item position exists.
In details:
in each nested list, all items can be numbered according to position like this:
;;   items:   1  2  3     1   2   3      1   2   3      1  2   3
(setq lst '(("1" a nil) ("2" nil 20.0) (nil nil 30.0) (nil nil 40.0)))
now how to create a new list from the original list if an item with a certain number exists? For example, when executing a function in which the first argument is a list of item number positions, then:
(somefunction '(1) lst)
;; =>> '(("1" a nil) ("2" nil 20.0))
(somefunction '(2) lst)
;; =>> '(("1" a nil))
(somefunction '(2 3) lst)
;; =>> '(("1" a nil) ("2" nil 20.0) (nil nil 30.0) (nil nil 40.0))
Kent1Cooper
For the first two:
(defun TEST (lst pos) (vl-remove-if-not '(lambda (x) (nth (1- pos) x)) lst))
(test lst 1)
(("1" A nil) ("2" nil 20.0))
(test lst 2)
(("1" A nil))
(test lst 3)
(("2" nil 20.0) (nil nil 30.0) (nil nil 40.0))
That's with a single position number [as just a number].  I'll have to think about the third situation a little....
Kent Cooper, AIA
ronjonp
Adding to Kent's solution to take care of the 3rd scenario:
(defun test (lst pos)
  (vl-remove-if-not '(lambda (x) (vl-some '(lambda (y) (nth (1- y) x)) pos)) lst)
(setq l '(("1" a nil) ("2" nil 20.0) (nil nil 30.0) (nil nil 40.0)("$" nil nil)))
(test l '(2 3))
;; (("1" A nil) ("2" nil 20.0) (nil nil 30.0) (nil nil 40.0))
Browning_Zed
Thank you for your help, dear sirs.
ronjonp
Glad to help 🍻
