(Command Modifier) from shortkeys
bemEYE67
bemEYE67
Hello
Can anyone help me with lisp routine about command "from". I need have this command modifier from one key, like for example command move by key m. I using autocad 2019.
ВeekeeCZ
Well, there is a disadvantage when using LISP that you'll need to call it with apostrophe... 'f.
It's a better option to assign _from macro (at CUI) it to one of Fx keys or to shortcut combo like Ctrl+Shift+F. Also is possible to use it as a temporaly override key (again Fx key)
