Good day. I am having an issue with vl-sort.
The list I am sorting has nested lists inside like this:
nList = ((a 1)(d 5)(c 2)(b 1))
I want to order the sublists in alphabetical order by their 1st element. I've included the entire routine for context and I've highlited the vl-sort functions in RED. I figure this is probably something very simple I'm missing and I am just not seeing it.
(defun c:testy ( / tCntr sList nList *error* fPath fName tFpath Cable Reduce ssText tVal sList sCntr
tVal1 tCnt mCntr tVal2 tToF tFile dspMsg nList equal1 more1)
(vl-load-com)
(setvar "cmdecho" 0)
(setq tCntr 0)
(setq sList ())
(setq nList ())
(defun *error* (msg)
(if (member msg '("Function cancelled" "quit / exit abort" "*Cancel*"))
(progn (setvar "cmdecho" 1)(princ "\n <!> Routine aborted <!> "))
) ;if
) ;*error*
(setq fPath "c:/Users/HULLZP/Desktop/CUSTOM")
(if (findfile fPath)
(progn (setq fName "/txtCount.txt")(setq tFpath (strcat fPath fName)))
(progn (princ "\n\033\n Invalid file path. See COUNTTEXT routine.")(exit))
) ;if
(princ "\n <ENTER> twice for default text count... ")
(initget "Y N")
(if (not (setq Cable (getkword "\n\033\n <Y> Reduce the selection set to cable numbers? [Y/N]: ")))
(progn (princ "\n Y or N required. Using default Y value!")(setq Cable "Y"))
) ;if
(initget "Y N")
(if (not (setq Reduce (getkword "\n\033\n <N> See only text with a count > 1? [Y/N]: ")))
(progn (princ "\n Y or N required. Using default N value!")(setq Reduce "N"))
) ;if
(if (and (princ "\n\033\n <> Select text objects to count: ")
(setq ssText (ssget '((0 . "TEXT")(8 . "TEXT")(67 . 0))))
) ;and
(while (< tCntr (sslength ssText))
(setq tVal (cdr (assoc 1 (entget (ssname ssText tCntr)))))
(cond
((= Cable "Y")
(if (and (> (strlen tVal) 10)
(wcmatch (substr tVal (- (strlen tVal) 3) 1) "-")
(= (vl-string-search "," tVal) nil)
(= (vl-string-search " " tVal) nil)
) ;and
(setq sList (append sList (list tVal)))
) ;if
((= Cable "N")
) ;cond
(setq tCntr (1+ tCntr))
) ;while
(progn (princ "\n\033\n < Selection set empty > ")(exit))
) ;if
(setq sCntr 0)
(setq tFile (open tFpath "w")) (close tFile)
(while (< sCntr (length sList))
(setq tVal1 (nth sCntr sList))
(setq tCnt 0)
(setq mCntr 0)
(while (<= mCntr (length sList))
(setq tVal2 (nth mCntr sList))
(if (= (equal tVal1 tVal2) T)(setq tCnt (1+ tCnt))) ;if
(setq mCntr (1+ mCntr))
) ;while
(if (= (member (list tVal1 tCnt) nList) nil) (setq nList (cons (list tVal1 tCnt) nList)))
(setq sCntr (1+ sCntr))
) ;while
(cond
((= Reduce "Y")
(progn
(foreach x nList (if (= (cadr x) 1) (setq nList (vl-remove x nList))))
(setq nList (vl-sort nList '(lambda (x y) < (car x) (car y))))
) ;progn
((= Reduce "N")
(progn
(foreach x nList
(if (= (cadr x) 1)
(setq equal1 (cons x equal1))
(setq more1 (cons x more1))
) ;if
) ;foreach
(if equal1 (setq equal1 (vl-sort equal1 '(lambda (x y) < (car x) (car y)))))
(if more1 (setq more1 (vl-sort more1 '(lambda (x y) < (car x) (car y)))))
(setq nList (append more1 equal1))
) ;progn
) ;cond
(foreach x nList (setq nList (subst (strcat (car x) " count is: " (itoa (cadr x))) x nList)))
(foreach x nList (progn (setq tFile (open tFpath "a"))(write-line x tFile)(close tFile)))
(cond ((and (= Cable "Y")(= Reduce "Y"))(setq dspMsg "cable numbers with counts greater than 1."))
((and (= Cable "Y")(= Reduce "N"))(setq dspMsg "cable numbers only."))
((and (= Cable "N")(= Reduce "Y"))(setq dspMsg "all cables and text with counts greater than 1."))
((and (= Cable "N")(= Reduce "N"))(setq dspMsg "all cables and text."))
) ;cond
(command "shell" tFpath)
(alert (strcat "Displaying: " dspMsg
"\n Please wait a moment while the text file is generated. \(" (itoa (sslength ssText)) " text objects\)"
"\n Larger selection sets \(1000+ text objects\) require additional time to process..."))
(princ (strcat "\n\033\n \(" (itoa (sslength ssText))))
(princ "\) text objects counted\n <!> Routine complete <!> ")
(princ)
) ;testy
