UNICODE Symbols
UNICODE Symbols
john.uhden
Mentor Mentor
UNICODE Symbols
john.uhden
What happened to my post of today?
Did I use a dirty word?
John F. Uhden
Kent1Cooper
It's >over in the the AutoCAD Forum<.
Kent Cooper, AIA
john.uhden
Why?
I wouldn't expect the general AutoCAD user to know much about object
properties and vlax-put.
John F. Uhden
Sea-Haven
Maybe the alt+keycode, try this Text pt ht etc hold ALT do key code let go alt press again do next alt+keycode.
Alt 066
Alt 073
Alt 071
Alt 065
Alt 076
You can go above the 128 for the extended keys.
Alt+252 & Alt+253  ² ³
(vla-get-textstring obj) using bricscad
"BIG¡▓¿²¹³AL"
john.uhden
Yes, I do that all the time for ° and ± and ÷
but unicode is beyond Alt+
There is no extended key for a capital delta /_\ *(that didn't come out too
well)*
BTW, I have found out that the Alt+ keys have to be entered using the
numeric keypad. That's part of the reason why I always buy a 17" laptop.
John F. Uhden
Sea-Haven
I have the number pad.
Had a play with mtext manually not sure program wise, pasted \U+0394 no quotes
This worked
(setq obj (vlax-ename->vla-object (car (entsel "Pick obj"))))
Pick obj#<VLA-OBJECT IAcadMText 000001e9f2cb5ff8>
 (setq str (strcat "John " "\U+0394" " Uhden"))
"John Δ Uhden"
(vla-put-textstring obj str)
