Hey everyone, thanks to @Z9E3zK5E, I obtained a LISP that inserts blocks by predetermining dynamic properties and attributes. For further step, I have a basic second command which creates lines according to insert point.
How can I merge these commands, according to insert point and previous LISP? I tried a little but, couldn't manage. I hope you may help. Thank you.
;INSERT BLOCKS
;Thanks to @ВeekeeCZ
(vl-load-com)
(defun c:144 ( / o dynprops atvalues)
(defun dtr (a)
(* pi (/ a 180.0))
(setq ang1 (dtr 25.0))
(command-s "_.-insert" "BLOCKNAME1" "_b" "0,-10" "_s" 1 "_r" 0)
(setq dynprops (list
(cons "Angle1" ang1)
'("Position1 X" . 10) ; all dyn-values are numbers - without ""
'("Position1 Y" . 10)
'("Position2 X" . 20) ; all dyn-values are numbers - without ""
'("Position2 Y" . 20)
'("Position3 X" . 30) ; all dyn-values are numbers - without ""
'("Position3 Y" . 30)
'("Position4 X" . 40) ; all dyn-values are numbers - without ""
'("Position4 Y" . 40)
atvalues '(
("TAG1" . "VALUE11")
("TAG2" . "VALUE22")
("TAG3" . "VALUE33")
("TAG4" . "VALUE44")
(setq o (vlax-ename->vla-object (entlast)))
(LM:setdynprops o dynprops)
(LM:vl-setattributevalues o atvalues)
(princ)
;; Set Dynamic Block Properties - Lee Mac
;; Modifies values of Dynamic Block properties using a supplied association list.
;; blk - [vla] VLA Dynamic Block Reference object
;; lst - [lst] Association list of (( . ) ... )
;; Returns: nil
(defun LM:setdynprops ( blk lst / itm )
(setq lst (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x))) lst))
(foreach x (vlax-invoke blk 'getdynamicblockproperties)
(if (setq itm (assoc (strcase (vla-get-propertyname x)) lst))
(vla-put-value x (vlax-make-variant (cdr itm) (vlax-variant-type (vla-get-value x)))))))
;; Set Attribute Values - Lee Mac
;; Sets attributes with tags found in the association list to their associated values.
;; blk - [vla] VLA Block Reference Object
;; Returns: nil
(defun LM:vl-setattributevalues ( blk lst / itm )
(foreach att (vlax-invoke blk 'getattributes)
(if (setq itm (assoc (vla-get-tagstring att) lst))
(vla-put-textstring att (cdr itm)))))
;LINE LISP
(defun c:S1 ( / p1 p2 p3 p4)
(setq p1 (getpoint "\nLine origin: "))
(setq p2 (mapcar '+ p1 '(5 5 0)))
(setq p3 (mapcar '+ p1 '(0 -5 0)))
(setq p4 (mapcar '+ p3 '(60 0 0)))
(setq p5 (mapcar '+ p3 '(-60 0 0)))
(setq p10 (mapcar '+ p2 '(5 -5 0)))
(setq p20 (mapcar '+ p10 '(5 0 0)))
(setq p30 (mapcar '+ p20 '(0 50 0)))
(setq p102 (mapcar '+ p1 '(-5 5 0)))
(setq p110 (mapcar '+ p102 '(-5 -5 0)))
(setq p120 (mapcar '+ p110 '(-5 0 0)))
(setq p130 (mapcar '+ p120 '(0 50 0)))
(entmakex (list '(0 . "LINE")(cons 10 p1)(cons 11 p3)))
(entmakex (list '(0 . "LINE")(cons 10 p3)(cons 11 p4)))
(entmakex (list '(0 . "LINE")(cons 10 p3)(cons 11 p5)))
(entmakex (list '(0 . "LINE")(cons 10 p2)(cons 11 p10)))
(entmakex (list '(0 . "LINE")(cons 10 p10)(cons 11 p20)))
(entmakex (list '(0 . "LINE")(cons 10 p20)(cons 11 p30)))
(entmakex (list '(0 . "LINE")(cons 10 p102)(cons 11 p110)))
(entmakex (list '(0 . "LINE")(cons 10 p110)(cons 11 p120)))
(entmakex (list '(0 . "LINE")(cons 10 p120)(cons 11 p130)))
