Change object plot style
M_c3d
Advisor Advisor
Message 1 of 8
M_c3d
Hi All,
I am trying to change a lisp I found online that changes all object colours including blocks, so that it also changes the plot style of all these objects at the same time.
;Changes the colour of
;all objects in drawing
;icluding blocks and references
;;IT WILL CHANGE ALL REF ALSO MAKE BACKUP OF ALL REF BEFORE USING
(defun mip:layer-status-restore ()
(foreach item *MIP_LAYER_LST*
(if (not (vlax-erased-p (car item)))
(vl-catch-all-apply
'(lambda ()
(vla-put-lock (car item) (cdr (assoc "lock" (cdr item))))
(vla-put-freeze (car item) (cdr (assoc "freeze" (cdr item))))
) ;_ end of lambda
) ;_ end of vl-catch-all-apply
) ;_ end of if
) ;_ end of foreach
(setq *MIP_LAYER_LST* nil)
) ;_ end of defun
(defun mip:layer-status-save ()
(vlax-for item (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
(setq *MIP_LAYER_LST* (cons (list item
(cons "freeze" (vla-get-freeze item))
(cons "lock" (vla-get-lock item))
) ;_ end of cons
*MIP_LAYER_LST*
) ;_ end of cons
) ;_ end of setq
(vla-put-lock item :vlax-false)
(if (= (vla-get-freeze item) :vlax-true)
(vl-catch-all-apply '(lambda () (vla-put-freeze item :vlax-false))))
) ;_ end of vlax-for
) ;_ end of defun
(defun ChangeAllObjectsColor (Doc Color )
(vlax-for Blk (vla-get-Blocks Doc)
(if (= (vla-get-IsXref Blk) :vlax-false)
(vlax-for Obj Blk
(if (vlax-property-available-p Obj 'Color)
(vla-put-Color Obj Color)
(defun C:CX ( / doc col)
(vl-load-com)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vla-startundomark doc)
(mip:layer-status-save)
(if (setq col (acad_colordlg 7 t))
(ChangeAllObjectsColor doc col);_ col — color number
(mip:layer-status-restore)
(vla-endundomark doc)
(princ)
(princ "\nType CX in command line")
I've tried various attempts at amending the code to include this but it never seems to pick it up.
Any ideas?
Thanks in advance!
Replies (7)
Message 2 of 8
ВeekeeCZ
Maybe like this?
      (vl-catch-all-apply
	'(lambda ()
	   ) ;_ end of lambda
      ) ;_ end of if
    ) ;_ end of foreach
  ) ;_ end of defun
				      ) ;_ end of cons
				*MIP_LAYER_LST*
				) ;_ end of cons
	  ) ;_ end of setq
  ) ;_ end of defun
(defun ChangeAllObjectsColorStb (Doc Color Stb)
      (vlax-for Obj Blk
	  (vla-put-Color Obj Color))
	(if (vlax-property-available-p Obj 'PlotStyleName)
	  (vla-put-PlotStyleName Obj Stb))))))
(defun C:CX ( / doc col stb)
  (vl-load-com)
  (if (and (setq col (acad_colordlg 7 t))
	   (setq stb (getstring "\nPlot style name: ")))
    (ChangeAllObjectsColorStb doc col stb);_ col — color number
  (princ)
Message 3 of 8
M_c3d
Thanks @ВeekeeCZ that works brilliantly!
Is it possible to specify the plot style, i.e. Red so it doesn't need to be input?
Message 4 of 8
ВeekeeCZ
Replace this line
with this one.
(setq stb "Red"))
Message 5 of 8
M_c3d
@ВeekeeCZ Thanks, appreciate the help.
Message 6 of 8
MSchille-1994
Is there a way to revise this .lsp to only have the ability to pick an object and set its layers plotstyle from a dialog box?
So basically, a change layers plotstyle dialog box?  I have cone for changing a layers color and I have another one to change a layers linetype, both by picking an object, then a dialog box pops up.
Attitude, not Aptitude, Determines Altitude
Message 7 of 8
ВeekeeCZ
Possibly like this.
If your using non-eng version change terms "ByLayer" "ByBlock" accordingly to your lang version. Those can't be removed from the list even not relevant.
(vl-load-com)
(defun c:LayerStb ( / *error* doc s i y l n o)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if o (setvar 'cplotstyle o))
    (princ))
  (if (and (or (= 0 (getvar 'pstylemode))
	       (prompt "Error: Current drawing must be in Named Plot Style mode."))
	   (setq s (ssget "_:L")))
    (repeat (setq i (sslength s))
      (setq y (cdr (assoc 8 (entget (ssname s (setq i (1- i)))))))
      (if (not (vl-position y l)) (setq l (cons y l)))))
  (and l
       (not (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))))
       (setq o (getvar 'cplotstyle))
       (setvar 'cplotstyle (getpropertyvalue (tblobjname "LAYER" (last l)) "PlotStyleName"))
       (progn
	 (initdia)
	 (command "_.plotstyle")
	 (setq n (getvar 'cplotstyle)))
       (or (not (vl-position n '("ByLayer" "ByBlock")))
	   (prompt "Error: ByLayer/ByBlock options are not applicable."))
       (if (= "Model" (getvar 'ctab))
	 (command "_.layer" "_ps" n (substr (apply 'strcat (mapcar '(lambda (x) (strcat "," x)) l)) 2) "")
	 (command "_.vplayer" "_ps" n (substr (apply 'strcat (mapcar '(lambda (x) (strcat "," x)) l)) 2) "_c" ""))
  (*error* "end")
Message 8 of 8
MSchille-1994
@ВeekeeCZ you are good.  Thanks so much.
