LISP ROUTINE - Merge Multiple LISPs
emreakyazicigsl
emreakyazicigsl
Hey everyone, thanks to @Z9E3zK5E, I obtained a LISP that inserts blocks by predetermining dynamic properties and attributes. For further step, I have a basic second command which creates lines according to insert point.
How can I merge these commands, according to insert point and previous LISP? I tried a little but, couldn't manage. I hope you may help. Thank you.
;INSERT BLOCKS
;Thanks to @ВeekeeCZ
(vl-load-com)
(defun c:144 ( / o dynprops atvalues)
(defun dtr (a)
(* pi (/ a 180.0))
(setq ang1 (dtr 25.0))
  (command-s "_.-insert" "BLOCKNAME1" "_b" "0,-10" "_s" 1 "_r" 0)
  (setq dynprops (list
		   (cons "Angle1" ang1)
		   '("Position1 X" . 10)			; all dyn-values are numbers - without ""
		   '("Position1 Y" . 10)
		   '("Position2 X" . 20)			; all dyn-values are numbers - without ""
		   '("Position2 Y" . 20)
		   '("Position3 X" . 30)			; all dyn-values are numbers - without ""
		   '("Position3 Y" . 30)
		   '("Position4 X" . 40)			; all dyn-values are numbers - without ""
		   '("Position4 Y" . 40)
	atvalues '(
			("TAG1" . "VALUE11")
			("TAG2" . "VALUE22")
			("TAG3" . "VALUE33")
			("TAG4" . "VALUE44")
  (setq o (vlax-ename->vla-object (entlast)))
  (LM:setdynprops o dynprops)
  (LM:vl-setattributevalues o atvalues)
  (princ)
;; Set Dynamic Block Properties  -  Lee Mac
;; Modifies values of Dynamic Block properties using a supplied association list.
;; blk - [vla] VLA Dynamic Block Reference object
;; lst - [lst] Association list of (( . ) ... )
;; Returns: nil
(defun LM:setdynprops ( blk lst / itm )
    (setq lst (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x))) lst))
    (foreach x (vlax-invoke blk 'getdynamicblockproperties)
        (if (setq itm (assoc (strcase (vla-get-propertyname x)) lst))
            (vla-put-value x (vlax-make-variant (cdr itm) (vlax-variant-type (vla-get-value x)))))))
;; Set Attribute Values  -  Lee Mac
;; Sets attributes with tags found in the association list to their associated values.
;; blk - [vla] VLA Block Reference Object
;; Returns: nil
(defun LM:vl-setattributevalues ( blk lst / itm )
    (foreach att (vlax-invoke blk 'getattributes)
        (if (setq itm (assoc (vla-get-tagstring att) lst))
            (vla-put-textstring att (cdr itm)))))
;LINE LISP
(defun c:S1 ( / p1 p2 p3 p4)
    (setq p1 (getpoint "\nLine origin: "))
    (setq p2 (mapcar '+ p1 '(5 5 0)))
    (setq p3 (mapcar '+ p1 '(0 -5 0)))
    (setq p4 (mapcar '+ p3 '(60 0 0)))
    (setq p5 (mapcar '+ p3 '(-60 0 0)))
    (setq p10 (mapcar '+ p2 '(5 -5 0)))
    (setq p20 (mapcar '+ p10 '(5 0 0)))
    (setq p30 (mapcar '+ p20 '(0 50 0)))
    (setq p102 (mapcar '+ p1 '(-5 5 0)))
    (setq p110 (mapcar '+ p102 '(-5 -5 0)))
    (setq p120 (mapcar '+ p110 '(-5 0 0)))
    (setq p130 (mapcar '+ p120 '(0 50 0)))
  (entmakex (list '(0 . "LINE")(cons 10 p1)(cons 11 p3)))
  (entmakex (list '(0 . "LINE")(cons 10 p3)(cons 11 p4)))
  (entmakex (list '(0 . "LINE")(cons 10 p3)(cons 11 p5)))
  (entmakex (list '(0 . "LINE")(cons 10 p2)(cons 11 p10)))
  (entmakex (list '(0 . "LINE")(cons 10 p10)(cons 11 p20)))
  (entmakex (list '(0 . "LINE")(cons 10 p20)(cons 11 p30)))
  (entmakex (list '(0 . "LINE")(cons 10 p102)(cons 11 p110)))
  (entmakex (list '(0 . "LINE")(cons 10 p110)(cons 11 p120)))
  (entmakex (list '(0 . "LINE")(cons 10 p120)(cons 11 p130)))
ВeekeeCZ
 Autocad stores the last point from his core commands (as INSERT is) in the  LASTPOINT system variable. So... use it.
(setq p1 (getvar 'lastpoint))
emreakyazicigsl
Oh, thank you so much.
