@АлексЮстасу
For correct results in coordinates in millions, I suggest that you temporarilly scale whole DWG from base WCS point 0,0 using scale factor 1e-8... Then when you get point(s), just multiply each point(s) coordinates with 1e+8 with using this syntax :
(mapcar (function (lambda ( x ) (mapcar (function (lambda ( y ) (* y 1e+8))) x))) pts), where pts is list of point(s) obtained from routine result... To make routine work faster, I removed all those zooms for which you stated as unneccessary, but I can't for sure guarantee that picking selection sets would perform correct - catching precisely only things crossing those start/end points of exploded entities, without selecting nearby other exploded things... So, here is my code - with just removed (zooms)...
(defun c:self-inters-overls ( / *error* unique isoobjs unisoobjs *lst* selfintlst ape ent cad obj1 el ss i e obj2 ellst ell sl lst )
(or
(not
(vl-catch-all-error-p
(vl-catch-all-apply
(function vlax-get-acad-object) nil
(vl-load-com)
(defun *error* ( m )
(if ape
(setvar (quote aperture) ape)
(if (and m (wcmatch (strcase m) "*EXIT*"))
(princ)
(if m
(progn
(prompt m)
(princ)
(if lst
(progn
(prompt "\nSelf-intersecting-overlapping points in WCS are : ")
(prompt "\n")
(read (vl-princ-to-string (unique lst 1e-6)))
(princ)
(defun unique ( lst fuzz / a ll )
(while (setq a (car lst))
(if (vl-some (function (lambda ( x ) (equal x a fuzz))) (cdr lst))
(setq ll (cons a ll) lst (vl-remove-if (function (lambda ( x ) (equal x a fuzz))) (cdr lst)))
(setq ll (cons a ll) lst (cdr lst))
(reverse ll)
(defun isoobjs ( s / ss i e enx rtn )
(setq ss (ssget "_X"))
(repeat (setq i (sslength ss))
(setq e (ssname ss (setq i (1- i))))
(if (and (not (ssmemb e s)) (not (vl-position (cons 60 1) (setq enx (entget e)))))
(progn
(entupd (cdr (assoc -1 (entmod (append enx (list (cons 60 1)))))))
(setq rtn (cons e rtn))
rtn
(defun unisoobjs ( *lst* )
(if *lst*
(foreach e *lst*
(entupd (cdr (assoc -1 (entmod (subst (cons 60 0) (cons 60 1) (entget e))))))
(defun selfintlst ( obj1 obj2 / lst rtn )
(setq lst
(vlax-invoke
(if (= (type obj1) (quote ename))
(vlax-ename->vla-object obj1)
obj1
(quote intersectwith)
(if (= (type obj2) (quote ename))
(vlax-ename->vla-object obj2)
obj2
acextendnone
(repeat (/ (length lst) 3)
(setq rtn
(cons
(list (car lst) (cadr lst) (caddr lst))
rtn
(setq lst (cdddr lst))
(reverse rtn)
(setq ape (getvar (quote aperture)))
(setvar (quote aperture) 1)
(if
(and
(setq ent (car (entsel "\nPick POLYLINE entity to get its self-intersecting-overlapping points...")))
(wcmatch (cdr (assoc 0 (entget ent))) "*POLYLINE")
(if
(not
(vl-catch-all-apply
(function vlax-curve-getstartpoint)
(list ent)
(progn
(setq *lst* (isoobjs (ssadd ent)))
(vla-zoomextents (setq cad (vlax-get-acad-object)))
(setq obj1 (vlax-ename->vla-object ent))
(setq el (entlast))
(vla-explode obj1)
(while (wcmatch (cdr (assoc 0 (entget (entnext el)))) "VERTEX,SEQEND")
(setq el (entnext el))
(while (setq el (entnext el))
(if (setq ss (ssget "_C" (trans (vlax-curve-getstartpoint el) 0 1) (trans (vlax-curve-getstartpoint el) 0 1)))
(if (= (cdr (assoc 0 (entget e))) "VERTEX")
(ssdel e ss)
(if (not (eq e (vlax-vla-object->ename obj1)))
(setq ell (cons e ell))
(if
(and
ss
(or
(> (sslength ss) 3)
(and
(= (sslength ss) 3)
(vl-some
(function
(lambda ( x )
(and
(not (equal (vlax-curve-getstartpoint x) (vlax-curve-getstartpoint el) 1e-6))
(not (equal (vlax-curve-getendpoint x) (vlax-curve-getstartpoint el) 1e-6))
ell
(setq lst (cons (vlax-curve-getstartpoint el) lst))
(setq ell nil)
(if (setq ss (ssget "_C" (trans (vlax-curve-getendpoint el) 0 1) (trans (vlax-curve-getendpoint el) 0 1)))
(ssdel e ss)
(if
(and
ss
(or
(> (sslength ss) 3)
(and
(= (sslength ss) 3)
(vl-some
(function
(lambda ( x )
(and
(not (equal (vlax-curve-getstartpoint x) (vlax-curve-getendpoint el) 1e-6))
(not (equal (vlax-curve-getendpoint x) (vlax-curve-getendpoint el) 1e-6))
ell
(setq lst (cons (vlax-curve-getendpoint el) lst))
(setq ell nil)
(setq obj2 (vlax-ename->vla-object el))
(setq sl (vl-catch-all-apply (function selfintlst) (list obj1 obj2)))
(if (and sl (not (vl-catch-all-error-p sl)))
(progn
(setq sl (vl-remove-if (function (lambda ( x ) (equal x (vlax-curve-getstartpoint el) 1e-6))) sl)
sl (vl-remove-if (function (lambda ( x ) (equal x (vlax-curve-getendpoint el) 1e-6))) sl)
(if sl
(setq lst (append sl lst))
(setq sl nil)
(setq ellst (cons el ellst))
(foreach el ellst
(if (and el (not (vlax-erased-p el)))
(entdel el)
(vla-zoomprevious cad)
(unisoobjs *lst*)
(progn
(prompt "\nInvalid entity pick... Picked entity must be POLYLINE... Better luck next time...")
(exit)
(prompt "\nMissed... or invalid entity pick... Picked entity must be POLYLINE... Better luck next time...")
(*error* nil)
HTH.
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
