The command to insert a block through the command line
AlexBern44
AlexBern44
I would like to upgrade the existing code for inserting blocks into a drawing via the command line.
This code is for inserting a block from the folder in which it is permanently stored.
My goal is that immediately after insertion, this block will explode into elements
An example of the original code:
(command "_.insert" "C:\Users\\User\\\Documents\\\Library\\Gates and fences\Fence 2" pause "" "" "")
Is it possible to make code that included both of these commands: insertion and explode in one line?
Alex
CraigP_
If I am not mistaken adding an asterisk (*) at the start of the filename will explode the block on insert.
(command "_.insert" "*C:\Users\\User\\\Documents\\\Library\\Gates and fences\Fence 2" pause "" "" "")
Craig
pbejse
(command "_.insert" "C:\\Users\\User\\Documents\\Library\\Gates and fences\\Fence 2.dwg"
	 pause "" "" "" "_explode" (entlast))
or adding "*" at the filename, but you wont see a preview when inserting the block
(command "_.insert" "*C:\\Users\\User\\Documents\\Library\\Gates and fences\\Fence 2.dwg" pause "" "" "")
Keep in mind that using the call to command "insert" pose some issues with the way the block is created
  • Scale uniformly
  • Attributes in blocks
  • Attributes setting , Attreq/Attdia..
  • Allow exploding* [ another can of worms ]
Others do it this way to deal with the issues on top of setting the system variables
(command "_.insert"
  "C:\\Users\\User\\Documents\\Library\\Gates and fences\\Fence 2.dwg" pause
(while (> (getvar "CMDACTIVE") 0)
  (command "")
(command "_explode" (entlast));<-- sometimes BURST for attributes with default value
So one line may not always work.
In your case where the block is known, you can force the settings and a one liner may work as expected,
HTH
AlexBern44
I thank you for this informative and helpful answer. This is exactly the code I was thinking about🌞
