Selection filter for 2dPolyline
Browning_Zed
Message 1 of 19
Browning_Zed
Hi All,
When using the entsel / nentselp function, I need to check if the picked object is "LWPOLYLINE" or "2DPOLYLINE". To check the LWPolyLine, I use the following expression:
(= (cdr (assoc 0 (entget (car (entsel "\nPick: "))))) "LWPOLYLINE")
how to make a check for 2DPolyLine besides this (not 3DPolyline)?
Replies (18)
Message 2 of 19
pbejse
@Browning_Zed wrote:
Hi All,
In terms of using entsel/nentsel/nentselp its basically the same as you already have
its just good habit to evaluate the values first
(while
  (setq e   (car (entsel "\nPick: ")))
	  (princ (Strcat "\nSelected Object is "
		  (cond
		    ((eq (setq etype (cdr (assoc 0 (setq ent (entget e))))) "LWPOLYLINE")
			" 2DPolyLine" 	)
		    ((eq etype	"POLYLINE") "3DPolyLine"
		    ( "Something else other than a Polyline")))
HTH
Message 3 of 19
Browning_Zed
Please, tell me, how to use the condition in this code:
(while
    (progn
        (setvar 'errno 0)
        (setq sel (nentselp "\nSelect LWPoly or 2DPoly <Exit>: "))
        (cond
            (   (= 7 (getvar 'errno))
                (princ "\nMissed, try again.")
            (   (= 'ename (type (car sel)))
                (if
                    (not
                        <<!!! OBJECT IS LWPOLY OR 2DPOLY !!!>>
                    (princ "\nInvalid object selected.")
Message 4 of 19
pbejse
Remember the loop will continue to prompt the user to select except the time the user press enter.
(defun c:demo ()
(while
    (progn
        (setvar 'errno 0)
        (cond
	     	(if (/= (cdr (assoc 0 (entget (car sel)))) "LWPOLYLINE")
		  	(princ "\nInvalid Object Selected.")
                        (princ "\n <<!!! OBJECT IS LWPOLY OR 2DPOLY !!!>> | Do something or press enter to exit the loop")
(princ)
Message 5 of 19
Browning_Zed
You do not understand me. I also need to check 2D polylines besides LW polylines.
This place in the code is marked like this: << HERE MUST BE CHECKED 2DPOLYLINE IS TRUE >>
(while
    (progn
        (setvar 'errno 0)
        (cond
                (if
                    (not
                        (or (= (cdr (assoc 0 (entget (car sel)))) "LWPOLYLINE") ; LWPOLY IS TRUE
Message 6 of 19
hak_vz
(and
	(setq eo (vlax-ename->vla-object e))
	(or
		(= (vlax-get eo 'Objectname)   "AcDbPolyline")
		(= (vlax-get eo 'Objectname)   "AcDb2dPolyline")
Miljenko Hatlak
Message 7 of 19
pbejse
Did you even try to understand the snippet i posted?
What is your idea of 2DPOLYLINE anyway? "LWPOLYLINE" is 2Dpolyline or "AcDbPolyline"
While POLYLINE is "AcDb3dPolyline" or "3D Polyline"
Message 8 of 19
Browning_Zed
When polylines are picked, your code returns results:
LW polyline: T
2D polyline: T
3D polyline: T
I need:
LW polyline: T
2D polyline: T
3D polyline: nil
Only LW polyline or 2D polyline should be selected.
Message 9 of 19
CADaSchtroumpf
By filtering?
(sssetfirst nil (ssget '((0 . "*POLYLINE") (-4 . "<NOT") (-4 . "&") (70 . 120) (-4 . "NOT>"))))
Message 10 of 19
Browning_Zed
LW polyline = "AcDbPolyline"
2D polyline = "AcDb2dPolyline"
3D polyline = "AcDb3dPolyline"
Message 11 of 19
pbejse
LW polyline: T
2D polyline: T
3D polyline: T
Maybe i'm missing something, can you post an example with those 3 diffrent types if polyline so we can be on the same page?
Message 12 of 19
hak_vz
LW polyline: T
2D polyline: T
3D polyline: T
I need:
LW polyline: T
2D polyline: T
3D polyline: nil
I' ve changed code above
Miljenko Hatlak
Message 13 of 19
pbejse
What?!!!?? there is an actual "AcDb2dPolyline"? 😮 silly me.
All these years and I did not know that?  Maybe i have not came across one before 🤔
Message 14 of 19
hak_vz
@pbejseYes, in dxf definition for POLYLINE entity is stands
100  Subclass marker (AcDb2dPolyline or AcDb3dPolyline)
Miljenko Hatlak
Message 15 of 19
Kent1Cooper
@pbejse wrote:
....What?!!!?? there is an actual "AcDb2dPolyline"? 😮 silly me.
Read about the PLINETYPE System Variable.  In addition to that determining whether new [non-3D] Polylines are "lightweight" [which are called "optimized" there] or "heavy," any time you use the Fit or Spline option in the PEDIT command on a LWPolyline, the result is a "heavy" 2D Polyline.
The confusion is understandable.  The entity type in entity data for both "heavy" 2D and 3D Polylines is (0 . "POLYLINE"), compared to (0 . "LWPOLYLINE") for "LightWeight" ones.  But in the Properties palette, a selected "lightweight" one is listed as just a "Polyline."  The other types have the "2D" or "3D" prefixes there.
Kent Cooper, AIA
Message 16 of 19
pbejse
FWIW
(defun c:demo ()
(while
    (progn
        (setvar 'errno 0)
        (setq sel (entsel "\nSelect LWPoly or 2DPoly : "))
        (cond
	     	(if ( not (member (vlax-get (setq ev (vlax-ename->vla-object (car sel))) 'Objectname) '("AcDb2dPolyline" "AcDbPolyline" "AcDb2dVertex")))
(princ)
Message 17 of 19
Browning_Zed
Thanks to hak_vz for solving the problem. Thanks pbejse too 🙂
As it was already noted, the confusion arises because of the same dxf codes for 2D and 3D polylines (0. "POLYLINE"), despite the fact that they are different objects.
I have attached a file where there are all three types of polylines: LW, 2D and 3D, if someone else needs it.
Message 18 of 19
Sea-Haven
red (0 . "POLYLINE") (100 . "AcDb2dPolyline")
green (0 . "POLYLINE")(100 . "AcDb3dPolyline")
white (0 . "POLYLINE")(100 . "AcDbPolyline")
Message 19 of 19
hak_vz
We have for polylines something like
(0 . "LWPOLYLINE")
(100 . "AcDbEntity")
This double key 100 may causes that not all entities are selected. Also for lwpolyline key 0 is not POLYLINE
Miljenko Hatlak
