TEMPLATE & DEFAULT LAYOUT
Message 1 of 12
hi everyone,
i have a situation at work where many times a draftsman closes a drawing in model
with 2 or 3 viewports and when it's a heavy drawing it takes time to open. i already setup
a drawing template, now what i wanted to happen is to set a certain layout so everytime
autocad opens that drawing it will always defaulted to one of the layout tab i set to be
the default no matter how the drawing was saved and closed, even if they saved it in
model, the next time they open it it will be the n default layout tab. is this possible?
any help or suggestion is much appreciated.
thank you.
Replies (11)
Message 2 of 12
john.vellek
Hi @Anonymous,
What version of AutoCAD are you using? Can you attach your template?
Perhaps you can create a home view and set this in options.
John Vellek
Message 3 of 12
hI john vellek,
I don't think this is what I wanted to do, I'm attaching my template as a dwg file.
what I wanted to do is everytime a drawing Is made from this template and wherever
they save and close the file, be it in model space or paper space, drawing will always
open n this layout tab I call "History". our file could have 6-10 layout tabs but this
"History" layout tab will always be located as the first layout tab and set as the default
tab every time drawing opens. I don't know if I'm explaining it well. thank you for youir time.
I'm using autocad MEP 2016.
Message 4 of 12
beyoungjr
Hi Mr. Lincoln:)
You have a good explanation, IMHO.
I too have wanted this functionality for my class templates.  Even though I save my dwt template files in a desired layout before providing it to the class, they sometimes finish their project dwg files and save with Model Space tab active.  I prefer a redirect to a specified Paper Space layout tab when opening the drawings made with my templates if it's possible to embed that setting in the drawing/template file itself vs. an application setting would only work on installations that have been tweaked with a setting.
Great idea!  Maybe an Autodesk wish list item if no current solution?
Blaine
Blaine Young
Senior Engineering Technician, US Army
Message 5 of 12
thank you Blaine, I'm glad I'm not alone on this. the other scenario on this is
that cad user are used to just double clicking the file and not using the open file
option. I guess this is not quite easy but I'm sure there are cad expert out there
that can do this and if not it's definitely worth it to include in the next patch or
somethin...
Message 6 of 12
john.vellek
Hi @Anonymous,
I get what you are trying to do here.  I can imagine a custom routine with a reactor that could move to the first tab on File Open.  I suggest that we move this thread to the customization forum to see if anyone has ideas or a routine that can work for you. Is this acceptable?
John Vellek
Message 7 of 12
beyoungjr
Not initially my post but I'd prefer the wish list instead of a customized routine that users would have to "employ to enjoy":)
Kinda like the Print/Plot dialog allowing you to "Apply to Layout" and having the ability stick to the file vs. the application.  I guess routines could be embedded in the dwg/dwt file too.  Love to see any ideas.
Blaine Young
Message 8 of 12
John Vellek,
yes, absolutely. thank you.
Message 9 of 12
Ranjit_Singh
@Anonymous wrote:
hi everyone,
thank you.
If lets say every drawing you opened always had a standard layout named "Info", then add this (setvar 'ctab "Info") to your acaddoc.lsp and it should always open that tab. Now, if you did not have that tab, it will print an error on the command prompt and continue with opening the drawing however it was saved.
Another way would be to make sure the drawing is saved in the desired layout by implementing a reactor, but I would not go there unless absolutely needed.
Message 10 of 12
Ranjit,
I will definitely try this and let you know the result. thank you.
Message 11 of 12
Ranji,
thank you, it works perfectly the way i wanted. i even tried double clicking the file
and it opens it to the layout tab i named. great.
Message 12 of 12
Ranjit_Singh
You are welcome. Glad it worked for you.
