plot with message option
Message 1 of 26
hi everyone,
i don't know how to name this in the subject but here is what i wanted to happen.
When i click "plot" my drawing, is there a way to insert a message that would pop
out in the screen  before going to the plot dialogue box.  our third party program has
the ability to the hidiing where it bottom objects will show dashed or hidden lines. i just
wanted to ask or remind my fellow draftsmen here at work if they did the hiding. so
when we click to "PLOT", a message would pop up like "Did you do Hiding? the an answer
would be a yes or no so that if yes it would continue plotting and if no it would cancel the
plot command. is this possible? maybe run a lisp before the plot command executes. i
appreciate every help or idea i can get.
thank you.
Replies (25)
Message 2 of 26
jggerth
undefine PLOT, and then redefine it in LISP to fire up an ALERT, and then run .plot
Message 3 of 26
Hi JGerth,
thanks for quick reply and i know exactly what you mean here but it's writing
that Lisp is my problem, it's been a long time and can't seem to do lisp again.
i'm assuming that the Alert is the lisp. anyway you can help me with this?
thank you.
Message 4 of 26
Kent1Cooper
Since an (alert) only has an OK check button, and doesn't offer a Yes/No choice, perhaps something like this [untested].  It puts up an alert so you can't help but notice, but then refers to the command line, where it gives the chance for a Yes/No choice.  It could be made to have No be the default, with a little revising.  It could be done with DCL for a dialog box that would put that Yes/No choice up in the middle of the screen, but that's a lot more complicated.  In simplest terms:
(command "_.undefine" "PLOT")
(defun C:PLOT ()
  (alert "Answer the Hiding question at the command line.")
  (initget "Yes No")
  (if (= (getkword "\nDid you do the Hiding? <Yes>: ") "No")
    (prompt "\nDo the Hiding, then Plot."); then
    (command "_.plot"); else -- either "Yes" or nil [Enter default]; proceed
  ); if
); defun
Kent Cooper, AIA
Message 5 of 26
john.uhden
Kent's answer is solid, but for important things, I like to use a message box that can provide Yes or No answers.
Copy the entire code into your acaddoc.lsp file.  If you're not sure where it is located, enter
(findfile "acaddoc.lsp")
at the command prompt.  It will return the full path.
(vl-load-com)
(defun C:PLOT ( / *error* cmd Doc Ans )
  ;*         PLOTALERT.LSP   by   John F. Uhden                                   *
  ;*                           2 Village Road                                  *
  ;*                           Sea Girt, NJ  08750                             *
  (gc)
  ;; This section initializes environmental and program variables:
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (setq cmd (getvar "cmdecho")
             Doc (vla-get-ActiveDocument *acad*)
  (defun *error* (error)
    (if (= (type cmd) 'INT)(setvar "cmdecho" cmd))
    (vla-endundomark Doc)
    (cond
      ((not error))
      ((wcmatch (strcase error) "*QUIT*,*CANCEL*"))
      (1 (princ (strcat "\nERROR: " error)))
    (princ)
;; MsgBox(prompt[, buttons][, title][, helpfile, context])
;; Buttons:
;; vbOKOnly    0 Display OK button only.
;; vbOKCancel    1 Display OK and Cancel buttons.
;; vbAbortRetryIgnore    2 Display Abort, Retry, and Ignore buttons.
;; vbYesNoCancel    3 Display Yes, No, and Cancel buttons.
;; vbYesNo    4 Display Yes and No buttons.
;; vbRetryCancel    5 Display Retry and Cancel buttons.
;; vbCritical   16 Display Critical Message icon.
;; vbQuestion   32 Display Warning Query icon.
;; vbExclamation   48 Display Warning Message icon.
;; vbInformation   64 Display Information Message icon.
;; vbDefaultButton1    0 First button is default.
;; vbDefaultButton2  256 Second button is default.
;; vbDefaultButton3  512 Third button is default.
;; vbDefaultButton4  768 Fourth button is default.
;; vbApplicationModal    0 Application modal; the user must respond to the message box before continuing work in the current application.
;; vbSystemModal 4096 System modal; all applications are suspended until the user responds to the message box.
;; Revised (01-27-03) thanks to Ed Jobe's contribution about snagging the return value.
(defun @msgbox (Title Buttons Message / useri1 value)
  (vl-load-com)
  (setq useri1 (getvar "useri1"))
  (acad-push-dbmod)
  (vla-eval
    *acad*
    (strcat
      "ThisDrawing.SetVariable \"USERI1\","
      "MsgBox (\""
      Message "\","
      (itoa Buttons) ",\""
      Title "\")"
  (setq value (getvar "useri1"))
  (setvar "useri1" useri1)
  (acad-pop-dbmod)
  value
  (vla-startundomark Doc)
  (setvar "cmdecho" 0)
  (command "_.expert" (getvar "expert")) ;; dummy command
  (setvar "cmdecho" 1)
  (setq Ans (@msgbox "PLOT WARNING" (+ 4 32) "Did you do the hiding?"))
  (if (= Ans 6)
    (command "_.plot")
    (@msgbox "PLOT WARNING" 48  "Do the Hiding, then Plot.")
  (*error* nil)
John F. Uhden
Message 6 of 26
scot-65
From my library of snippets/code blocks discovered on this forum:
;by hmsilva 7-28-2015
;Yes / No prompt
(defun c:deltext (/ ss)
  (if (and (setq ss (ssget "x" (list (cons 0 "text"))))
           (= (ACET-UI-MESSAGE
                "Do you want to delete all texts?"
                "You are about to delete all texts!!!"
                (+ Acet:YESNO Acet:ICONQuestion)
              6
    (command ".erase" ss "")
    (princ "\nNo text in this drawing!")
  (princ)
(I cannot readily find the ACET codes, sorry)
Rework to your liking...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 7 of 26
john.uhden
I think that "ACET" stands for AutoCAD Express Tools.
I happen to be one of those stubborn idiots who trusts my own work better.  Ya never know when Autodesk will take something away, or make it obsolete.
Correction: Dale Fugier's continued DOSLIB contributions remain without question.
John F. Uhden
Message 8 of 26
hi Kent,
thank you for helping out. i tried this by saving this as a separate .lsp file and just
loaded. it actually works but the only problem is when "yes" it goes to a few questions
of plot configurations, i was hoping that when you answer yes it will bring me to the
regular plot dialogue box. i'm guessing because we undefine the plot command that
i looses the whole plot command and replaced by this .lsp. is it possible that when you
answer yes it will just bring back the original plot command. thank you again.
Message 9 of 26
hi john.uhden,
thank you for helping out too. like kent i save this file as a separate .lsp file just to test it out.
it loads successfully but it giving me error after clicking the plot command. see below.
Command: APPLOAD
practi_hiding_alert.lsp successfully loaded.
Command: _.undefine
Enter command name: PLOT
Command:
Command:
Command:
Command:
Command:
Command: _PLOT
ERROR: Automation Error. Problem in loading VBA
it will be nice to have the diaglogue box, anyway you can tell from this?
thanks again.
Message 10 of 26
Kent1Cooper
@Anonymous wrote:
.... i was hoping that when you answer yes it will bring me to the regular plot dialogue box....
It's only that dialog-box-based commands operate in command-line version when called from inside a (command) function, unless you force them to call up the dialog box with a preceding (initdia) function.  The period/decimal before the command name does bring up the "regular" AutoCAD command.  Try this modification:
(defun C:PLOT ()
  (initget "Yes No")
(progn ; else -- either "Yes" or nil [Enter default]; proceed
(initdia) (command "_.plot")
); progn ); if ); defun
Kent Cooper, AIA
Message 11 of 26
john.uhden
Try adding this line to the top of the code:
(arxload "acadvba.arx" nil)
Also, Kent's recommendation of including (initdia) is sound.
I think you will have to change the code from:
(command "_.plot")
to
(progn
  (initdia)
  (command "_.plot")
John F. Uhden
Message 12 of 26
Kent,
this one works just as i ask for. one more tweak if i can ask, users are used
to seeing "yes or no" answer with default 'yes' is great. thanks again.
Message 13 of 26
johm,
i added the line you wanted me to add. it still gives me the same
message as the first time. i attached the file.
Message 14 of 26
Kent1Cooper
@Anonymous wrote:
.... one more tweak if i can ask, users are used to seeing "yes or no" answer with default 'yes' is great. ....
If you mean they're used to having those answer choices shown in the prompt, they're easily added:
  (if (= (getkword "\nDid you do the Hiding [Yes/No]? <Yes>: ") "No")
That format also has the nice advantage that [in new-enough versions] the User can pick on the option in the prompt itself at the command line.
Kent Cooper, AIA
Message 15 of 26
john.uhden
The default is "Yes" so the user can just hit Enter rather than pick the
"Yes" button.
John F. Uhden
Message 16 of 26
john.uhden
"Yes" button.
John F. Uhden
Message 17 of 26
thank you much kent, i appreciate the effort and help.
Message 18 of 26
Ranjit_Singh
I like @john.uhden's idea of presenting a dialog box. I just tried it out and it works great at my end. Since you are getting a VBA error try below alternative.
(vl-load-com)
(defun c:plot  (/ wsobj)
 (if (= 7 (vlax-invoke (setq wsobj (vlax-get-or-create-object "wscript.shell"))
                     'popup "Did you do the hiding?" 5 "Plot Warning" 4))
  (progn (vlax-invoke wsobj 'popup "Do the hiding and plot" 5 "Plot Warning" 0)
         (vlax-release-object wsobj))
  (progn (initdia) (command "._plot")))
(princ))
Message 19 of 26
sdeschneauEADWZ
Could the final version of this be shared to me? New @ Lisp files and I had a hard time following the resolution here. Thank you.
Message 20 of 26
Kent1Cooper
@sdeschneauEADWZ wrote:
Could the final version of this be shared to me? ....
Which approach?  If you're talking about what's marked as the accepted solution, just take the blue bits from Message 14 and put them into the code from Message 10 at the equivalent place.
Kent Cooper, AIA
