Lisp to Size Pipes
Lisp to Size Pipes
107199
Lisp to Size Pipes
107199
hi,
is there is any ideas how to make lisp with these steps:
1-find all text contain "L/S"
2-copy all these text "350mm" up
3-replace these text each with "pipe size" which depend on the flow "L/S" according to table in attached photo with suffix "mm"
this picture for the final output
Ranjit_Singh
It seems like it should be possible with a fairly simple routine. Is that an AutoCAD table or OLEObject? Post a drawing.
alanjt_
What if the L/S value doesn't match anything in the table? (eg. 0.063 Vs)
_Tharwat
Actually it should be less or equal:
(defun pipesize (lps / ps)
(vl-some
'(lambda (v) (and (<= lps (car v)) (setq ps (cadr v))))
'((0.3 20) (0.57 25) (1.21 32)))
ps)
 OP, just add the rest of your table as per my adds in the above sub-function.
scot-65
Looks like a dynamic block with a LOOKUP linked
to a Visible State would do the trick.
The L/S shown in the screen capture has values that
are not showing in the table.
"< 0.30"
"< 0.57"
"< 1.21"
... seem to be the appropriate Lookup display.
My question would be:
Are L/S values fixed?
If not, include an attribute in the block for L/S?
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
