Zoom Extents
Zoom Extents
Zoom Extents
Does anyone have a lisp routine for zoom extents? I see plenty for zoom extents all layouts, but I want just the current layout. I used to have one, but lost it, and don't know enough about lisp routines to write my own. Thanks!
Kent1Cooper
This is what I use -- a little command called ZE.  Not much of a shorthand compared to Z [space] E [space], but I do use it a lot, and you can put it in a menu item somewhere so you can just pick it:
(defun C:ZE (); Zoom Extents
  (command "_.zoom" "_extents")
  (princ)
More often, I use Zoom to the Limits [ZL command], but I understand a lot of people don't make use of drawing Limits as I do:
(defun C:ZL (); Zoom Limits
  (command "_.zoom" (getvar 'limmin) (getvar 'limmax))
  (princ)
Kent Cooper, AIA
Thank you so much! That was exactly what I was looking for!
scot-65
I will share a supplement to Kent's Zoom Limits.
I too like to use Zoom Limits since here we have a "checkerboard"
setup in model space and sometimes one gets lost as to where
one left off...
c:ZZR will set LIMMIN and LIMMAX - Specify a 2-point rectangle.
c:ZZZ is Zoom Limits.
Enjoy.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
That's very interesting. Thanks for sharing that with me. I'll give it a try!
Kent1Cooper
@Anonymous wrote:
Does anyone have a lisp routine for zoom extents? ....
By the way, I forgot that, in fact, no routine is needed [if you have a new-enough version for this -- I don't know when it came in -- and have a mouse with a wheel].  Just double-clicking on your mouse wheel gets you Zoom Extents.  [I wrote that routine in an older version when this wasn't available.]
Kent Cooper, AIA
Well how about that! I had no idea that you could do that! Thanks for the tip!
