Tee and 90 block insertion Lisp
smallƑish
Message 1 of 9
smallƑish
I need a Lisp for AutoCAD that can insert elbows and tees at junctions be as follows:
select a few objects , Prompt the user to select a layer through a pop-up  with the following options:
Cold Water
Hot Water
If "Cold Water" is selected:
Exclude all others layered objects from from the selection (if any).
Insert a 90-degree elbow at each polyline vertex that forms a 90-degree angle, ensuring correct orientation.
Insert a tee block at junctions, properly oriented.
For better understanding, I have attached a screenshot and a DWG file.
Thank you so much!
Replies (8)
Message 2 of 9
ronjonp
@smallƑish What determines that a tee goes here?
Message 3 of 9
pendean
Community Legend
Community Legend
@smallƑish Are you folks not using the MEP variant of AutoCAD? Free to all subscribers to install and use
https://forums.autodesk.com/t5/autocad-mep-forum/does-autocad-mep-produce-reducing-tees-and-elbows/t...
Message 4 of 9
Sea-Haven
Do a google for possible answers they are out there. Go to the Autocad Appstore and have a look.
Message 5 of 9
smallƑish
It was a mistake from my end. Please ignore it.
Message 6 of 9
smallƑish
It was a mistake please ignore it.
Message 7 of 9
smallƑish
I tried that, as it's more advanced, It has its own complications.
Message 8 of 9
smallƑish
There are a few, most of them are hints. Not a proper one what explained above.
Message 9 of 9
Sea-Haven
Check appstore again pretty sure Tharwat has a solution. He is often here so he will probably comment.
