Convert attribute text to a field with a hyperlink
JBerns
Advisor Advisor
Message 1 of 8
JBerns
Community,
I have a title block that contains several attributes. One of the attributes is a DWGREF (drawing reference).
Currently it just stores text (drawing number) typed by the designer.
My goal is to convert the attribute from text to a Field that stores a hyperlink.
This can all be done manually. My goal is to automate with AutoLISP or Visual Lisp.
I have searched the forums and tasked AI tools to write the code, but have been unsuccessful.
Here is the code I have so far:
;;; Convert attribute text to a field and hyperlink
(defun C:ConvertAttribToHyperlink (/
				   atttag blkAttribs blkData blkEnt blkName foundAttTag hyperlinkurl ss)
  ;; defaults
  (setq blkName      "MyBlockName"        ;; block name
	attTag       "MyAttribTag"           ;; attribute tag name
	hyperlinkURL "http://example.com" ;; hhyperlink
	) ;_setq
  ;; Create the selection set using ssget with filters:
  (setq ss (ssget "_X" (list (cons 0 "INSERT")    ;; Filter for block references (INSERT)
                             (cons 2 blkName))))  ;; Filter for block name
  ;; Check if the selection set is valid
  (if ss
    (progn
      (setq blkEnt  (ssname ss 0)         ;; Get first block (for now) from selection set
	    blkData (entget blkEnt)       ;; Get the entity data
	    ) ;_setq
      (if (and blkEnt blkData)
	(progn
	  ;; Get the block reference attributes
	  (setq blkAttribs (vlax-invoke (vlax-ename->vla-object blkEnt) 'GetAttributes))
	  ;; Loop through attributes to find the attribute tag
	  (setq foundAttTag nil)
	  (foreach att blkAttribs
	    (if (= (vla-get-tagstring att) attTag)
	      (progn
		(setq foundAttTag t)     ;; Set flag if attribute found
		;;; This is where I need to insert a field into the attribute
		;;; and then set the field to store a hyperlink
              ) ;_progn
	    ) ;_if
	  ) ;_foreach
	) ;_progn
      ) ;_if
    ) ;_progn
    (princ (strcat "\nNo block named, '" blkName "' found in the drawing."))  ;; No blocks found
  ) ;_if
  (princ)
) ;_C:ConvertAttribToHyperlink
(princ)
Lines 35 - 38 are where I would expect the conversion to occur.
I cannot determine how to "insert" a field into the attribute text.
Once the field is inserted, a hyperlink needs to be set in the field.
Here is some text I discovered when manually inserting the field and hyperlink:
I have attached a drawing with block and attribute that match the code.
Thank you for your time attention. I look forward to your replies.
Jerry
P.S. I found this forum post, but it uses VB.NET
https://forums.autodesk.com/t5/net/inserting-block-amp-adding-fields-to-attributes/m-p/6423370#M4927...
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Replies (7)
Message 2 of 8
paullimapa
These are the modifications I made:
Changed:
To also filter selection to blocks with attributes only:
                             '(66 . 1)            ;; contains attributes
Instead of the following sections of code:
;	  ;; Get the block reference attributes;
	      (progn
      ) ;_progn
	    ) ;_if
	  ) ;_foreach
I assume that there's a matching attribute tagname and then simplified the code to this:
;        inserts a field with hyperlink into the attribute
;        assumes block contains attribute with matching tagname
         (setpropertyvalue blkent atttag (strcat "%<\\AcVar \\href \"" hyperlinkURL "##" (substr hyperlinkURL 8) "#1\">%"))
         (command "_.UpdateField" blkEnt "")
Paul Li
IT Specialist
@The Office
Message 3 of 8
JBerns
@paullimapa (Paul),
Brilliant! I thought it was going to require a more complex solution involving VLA/VLAX functions.
Thank you, Paul!
Kind regards,
Jerry
CAD Administrator
Message 4 of 8
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
Message 5 of 8
JBerns
This morning I was testing hyperlinks to other AutoCAD drawings. For example, C:\Temp\123456.DWG.
I can get the hyperlink to work, but for some reason AutoCAD changes from a 'Maximized' window to a 'Restore Down' window size.
Annoying.
AutoCAD normally opens maximized.
Any suggestions as to how to prevent AutoCAD (or Windows OS) from changing the window size?
Jerry
CAD Administrator
Message 6 of 8
paullimapa
Seems to be a bug that’s been around for awhile
https://forums.autodesk.com/t5/autocad-forum/hyperlink-to-another-dwg-minimizes-window/td-p/7945504
Paul Li
IT Specialist
@The Office
Message 7 of 8
JBerns
Thanks for verifying, Paul.
CAD Administrator
Message 8 of 8
paullimapa
Once again you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
