TabName as Filename
TabName as Filename
SAFizzy
TabName as Filename
SAFizzy
Hello to all
i have small lisp to change tabname as file name, but i want this to be used as batch/Multiple files name. can some one help into modify this lisp.
(DEFUN C:RRT ()
(command "-layout" "rename" "" (vl-filename-base (getvar "dwgname")))
(princ)
Regards
dbhunia
@SAFizzy wrote:
Hello to all
you can try the approach of This post
(defun c:BatchJob (/ dwgs file dwgName scrFile folderName)
  (setq folderName
  (browsefolder "Select folder to perform batch job: ")
  (setq dwgs (vl-directory-files folderName "*.dwg"))
  (setq scrFile (open (strcat folderName "\\batchJob.scr") "w"))
  (foreach file dwgs
	(setq dwgName (strcat "\"" folderName "\\" file "\""))
	(write-line ".Open" scrFile)
	(write-line dwgName scrFile)
	(write-line "-layout rename  (vl-filename-base (vla-get-Name (vla-get-ActiveDocument (vlax-get-acad-object))))" scrFile)
	(write-line ".Qsave" scrFile)
	(write-line ".close" scrFile)
  (close scrFile)
  (command ".script" (strcat folderName "\\batchJob.scr"))
  (princ)
;;; Function to browse folder
;;; This code was originally posted by kpblc2000 in AUGI AutoLisp Forum
(defun browsefolder (title / shlobj folder fldobj)
  (vl-load-com)
  (setq shlobj (vla-getinterfaceobject (vlax-get-acad-object) "Shell.Application")
		folder (vlax-invoke-method shlobj 'browseforfolder 0 title 0)
  (vlax-release-object shlobj)
  (if folder
	(progn
	  (setq fldobj(vlax-get-property folder 'self)
			folderName (vlax-get-property fldobj 'path)
	  (vlax-release-object folder)
	  (vlax-release-object fldobj)
	  folderName
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
SAFizzy
@dbhunia
Thanks for help
exactly what i needed
