Constraints on Object Model
Langephd
Langephd
Autocad 2020
Is there a way to access constraints and parameters properties and methods through de Object Model?
Alfred.NESWADBA
Can you please describe what you describe as "Object Model" ... or show a dwg-file?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Langephd
Thanks for your answer.
I am referring to Object Model (Activex) which describes the properties and methods of objects in the Autocad drawing.
JoJo
Alfred.NESWADBA
AFAIK it's not available through COM/ActiveX.
You can access it e.g. using .NET, some links to that can be found >>>here<<<
- alfred -
Alfred NESWADBA
Langephd
Thanks Alfred.
I think that answers my question.
JoJo
