disable input history generation
Moshe-A
Mentor Mentor
Moshe-A
hi guys,
i googled a lot and couldn't find solution for this one. i wonder if it's possible to disable (temporarily) the generation of INPUTHISTORY. i wrote an autolisp (activex) application that add a list of menu items to the default "edit menu" which comes at right click on a selected object(s) and the macros to execute is a call to an autolisp function and i use ^P to disable the prompt at the command line but the call is still seen from the shortcut menu Recent Input .
thanks in advanced
moshe
CodeDing
@Moshe-A ,
Have you already tried putting INPUTHISTORYMODE to 0? Then restore after? For my very limited testing, this seemed to work fine.
Best,
~DD
Moshe-A
@CodeDing,
yes i did try it and at the first it look like it still recording the 'actions' but now as i test it again it do the trick
so thank you very much for this help.
moshe
