Sysvar Changed Reactor and REGEN
scot-65
Advisor Advisor
scot-65
R2024 LT
I am trying to take advantage of CENTERLAYER, DIMLAYER, HPLAYER, and TEXTLAYER as part of our workflow. When the user selects a layer to be current using the toolbar or ribbon control, I am able to
trap this CLAYER change thru the Sysvar Changed Reactor and thaw these associative layers; if frozen.
(setpropertyvalue (tblobjname "layer" (strcat r x)) "IsFrozen" 0)
The issue I am having is these associative layers will become thawed, but do not show.
(redraw) and
(redraw (tblobjname "LAYER" "MYtextlayer")) does not work.
Any ideas how to get these associative layers to display?
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
paullimapa
How’s about a regen?
Usually a regen is required to show objects on thawed layers. Another workaround I’ve used is to try ssget filter all those objects on those layers and then do a move in place
Paul Li
IT Specialist
@The Office
scot-65
I have tried
VL-CMDF and
ENTUPD with no success.
@paullimapa
The sequence is nested inside a reactor event where commands are not allowed.
:vlr-sysvarWillChange does not supply the proposed value, only the variable name itself.
Possibly some sort of vla-get-Layer (not Layers) method with some sort of a vla regen?
I do not want to loop thru a _rather large_ layer list.
Scot-65
paullimapa
Perhaps try vla-regen if this method is allowed
https://www.afralisp.net/archive/methods/lista/regen_method.htm
Paul Li
IT Specialist
@The Office
scot-65
This did the trick.
(vla-Regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport) ;-or- acAllViewports
Leaves command line chatter though.
"Regenerating model."
and
"Command:"
Scot-65
paullimapa
Better than not seeing anything…cheers!!
Paul Li
IT Specialist
@The Office
