Using multiple visibilty parameters in a dynamic block
mehdi-guida
Message 1 of 10
mehdi-guida
Hi
Is there any way to use multiple visibilty parameters in a dynamic block by Lisp routine?
Replies (9)
Message 2 of 10
braudpat
Hello
YES there is a way with a special Lisp routine ...
The Topic is French and I will try to translate it !
https://forums.autodesk.com/t5/autocad-tous-produits-francais/autocad-peut-on-faire-plusieurs-parame...
https://forums.autodesk.com/t5/autocad-tous-produits-francais/autocad-mise-a-jour-d-un-lisp-entre-au...
It is possible with the Lisp "visibility-add-eng_1_6.lsp"
You must :
- Open your DWG with the Dynamic Block
- Open the Dynamic Block into the Block Editor (BEDIT)
- Load (APPLOAD) the Lisp "visibility-add-eng_1_6.lsp"
You must load it INTO the Block Editor
AND your Block MUST HAVE already a Visibility State !
- Command: VSPADD
- CLIC on new Insertion Point of the NEW Visibility State and wait ...
- Update / Save ...
- NOW it s OK !?
OK for you ?
Bye, Patrice (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 10
Sea-Haven
Get a copy of Lee-mac Dynamic block properties lisp. Has all the functions you need.
Not a problem to select and set dynamic visibility. Example a house window.
Message 4 of 10
mehdi-guida
Thank you for reply.
I couldn't find anything for creating multiple visibility parameters in Lee-mac lisps.
I want to create more than one visibility parameter in a dynamic block.
Message 5 of 10
pendean
Community Legend
Community Legend
The dedicated Dynamic Blocks forum may be the best place to post and ask to accomplish your need, here is the link
https://forums.autodesk.com/t5/dynamic-blocks-forum/bd-p/154
Message 6 of 10
Sea-Haven
Google "making dynamic block visibility states"
I do some work for a client and they have  30 images as visibility states in one block.
Message 7 of 10
king
I'm not seeing how to modify the visibility states once I add the secondary vis state in. I have it inserted into my block with no option to add addition states to it
Message 8 of 10
Sea-Haven
Use Google and watch some of the Utube videos.
Message 9 of 10
mehdi-guida
Thank You for reply.
Would You please take a video of creating 2 visibility states for a dynamic block?
Message 10 of 10
Sea-Haven
I can not help with creating dynamic block visibilty states. Others may have some suggestions.
