Block layer fix for multiple blocks
DC-MWA
Message 1 of 14
DC-MWA
I have inherited a project and received cad files for the project. I need help fixing the block layers.
All the blocks are on layer 0, and each block has a layer inside the block.
I need to put the block on the layer inside the block, and set the block layer to 0.
Example.
Existing:  Sink block on layer "0" and geometry inside block is on layer "A-Appl".
Desired: put Sink block on layer "A-Appl" and geometry inside block to be on layer "0".
There are dozens of blocks that need to be corrected. I'm hoping to selected multiple blocks at once.
I'm hoping somebody has run into this before and has a solution.
Thanks in advance for your assistance.
-dc
Replies (13)
Message 2 of 14
komondormrex
hey there,
yet another one. no checks on layers' lock.
(defun c:change_layer_all_inserts ( / block_definition processed_list insert_layer block_name insert_dxf)
	(vlax-map-collection (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
		'(lambda (insert)
			(if (and
				 (= "AcDbBlockReference" (vla-get-objectname insert))
				 (zerop (vlax-get (setq block_definition (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
										   (vla-get-effectivename insert)
						  ) 'isxref
		      		(if (not (assoc (setq block_name (vla-get-name block_definition)) processed_list))
				  	(setq processed_list (append processed_list (list (cons (vla-get-name block_definition) (vla-get-layer (vla-item block_definition 0))))))
				  	(vla-put-layer insert (cdr (assoc block_name processed_list)))
				(progn
					(vlax-map-collection block_definition
						'(lambda (object)
							(progn
								(vla-put-layer object "0")
	;								(vla-put-color object 256)
  	(vla-regen (vla-get-activedocument (vlax-get-acad-object)) acactiveviewport)
  	(princ)
updated_2
Message 3 of 14
smallƑish
Try this, got from internet only.
Message 4 of 14
DC-MWA
I appreciate the replies. All of these only set the block layers to "0" which is half the battle.
I need to extract the layer inside the block put the block on that layer in addition to setting the layer inside the block to "0".
Message 5 of 14
pendean
Community Legend
Community Legend
If you want to do the work... here is a lisp that is your requested process https://forums.augi.com/showthread.php?18929-Block-layer-Lisp-Finder&p=119922&viewfull=1#post119922 and you have the latter requested process above.
HTH
Message 6 of 14
DC-MWA
Thank you. This does get the layer from the blocks selected. This is beyond my limited skill set.
Worse case I will get to work manually putting blocks on the appropriate layers.
Message 7 of 14
komondormrex
sure, check update
Message 8 of 14
ronjonp
@DC-MWA Give this a shot:
(defun c:foo (/ blk lyr nm r)
  ;; RJP » 2024-01-30
  (vlax-for a (setq blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
    (if	(and (= 0 (vlax-get a 'islayout) (vlax-get a 'isxref)) (setq nm (vla-get-name a)))
      (vlax-for	b a
	(and nm (/= "0" (vla-get-layer b)) (setq r (cons (list nm (vla-get-layer b)) r)))
	(vl-catch-all-apply 'vla-put-layer (list b "0"))
	(setq nm nil)
  (vlax-for a blk
    (if	(= -1 (vlax-get a 'islayout))
      (vlax-for	b a
	(and (= "AcDbBlockReference" (vla-get-objectname b))
	     (setq lyr (cadr (assoc (vla-get-effectivename b) r)))
	     (vl-catch-all-apply 'vla-put-layer (list b lyr))
  (princ)
Message 9 of 14
DC-MWA
This works. Is it possible to make it work on selected blocks only. Because if it does all the blocks, the blocks that are setup correctly end up on layer 0.
Message 10 of 14
ronjonp
@DC-MWA Try the code again .. I put an exception if the internal layer is already "0".
Message 11 of 14
DC-MWA
Thank you very very much.
I am burning through drawings lighting fast!!!
Message 12 of 14
ronjonp
You're welcome! 😁
Message 13 of 14
studiocz
can you please explain me how to use the written lisps/  i know how to load lisp files but dont know how to turn the written comand to a file and load
Message 14 of 14
Sea-Haven
The program is ran by typing Foo on command line after loading. I would rename it to something else that matches the task. Blayfix ??
 The C: implies that what follows can be used as a command.
The second option is to add (c:foo) as the last line in the lisp this will run it after its loaded, if you want to run again just type FOO.
(princ)
(C:foo)
