strip mtext formatting
mruPRQUJ
8,682件の閲覧回数
58件の返信
メッセージ1/59
mruPRQUJ
Is it possible to create a lisp to strip mtext formatting? like, width factor, tracking and oblique angle. The attached lisp can strip mtext, but not formatting. Thank you very much in advance, 🙂
0 件のいいね
解決済み
8,683件の閲覧回数
58件の返信
返信 (58)
メッセージ2/59
pendean
Community Legend
Community Legend
@mruPRQUJ wrote:
... like, width factor, tracking and oblique angle....
https://github.com/Fandoozle/AutoCAD/blob/master/StripMtext%20v5-0c.lsp
メッセージ3/59
mruPRQUJ
Width and width factor are two different items, many thanks. 🙂
0 件のいいね
メッセージ4/59
john.uhden
@mruPRQUJ ,
In the file you included you can see what formats are covered..
;;;; Available format key codes
;;;; "A" = Alignment
;;;; "B" = taBs
;;;; "C" = Color
;;;; "D" = fielDs (converts fields to static text)
;;;; "F" = Font
;;;; "H" = Height
;;;; "L" = Linefeed (newline, line break, carriage return)
;;;; "M" = background Mask
;;;; "N" = columNs
;;;; "O" = Overline
;;;; "P" = Paragraph (embedded justification, line spacing, indents)
;;;; "Q" = obliQue
;;;; "S" = Stacking
;;;; "T" = Tracking
;;;; "U" = Underline
;;;; "W" = Width
;;;; "~" = non-breaking space
;;;; "*" = all formats
Of course I must defend Joe and Steve because I had donated the code they used in v3.0.
I still use my original UNFORMAT.LSP, but I think that STRIPMTEXT does more.
John F. Uhden
メッセージ5/59
mruPRQUJ
Width is different with width factor. Could you please advise how to remove width factor only? Please see the image below, thank you very much! 🙂
width factor
Width
0 件のいいね
メッセージ6/59
pendean
Community Legend
Community Legend
Got it: standalone LISP while you wait... see comments below that for additional adjustments https://forums.autodesk.com/t5/autocad-forum/mtext-width-factor/m-p/10397965#M1054795
There are more examples you can find with a search of these forums.
メッセージ7/59
john.uhden
@mruPRQUJ ,
I'm sure UNFORMAT.lsp is somewhere in this database, but if you can't find it, let me know.
An older version (that may be at home) enabled you to select the overrides to remove, but I simplified it to attack all the overrides I knew 18 years ago.  It doesn't handle attributes.
Now if the improper width factor is applied to the entire contents, but there is no override, then check and maybe change the text style's properties.
John F. Uhden
メッセージ9/59
john.uhden
@pendean ,
I see you are filling in for @hak_vz .  😏
Yes, that's the original function from 2003.  It provides for user input as to what formatting to remove.
My later version eliminated the alpha choices.
My latest version handles MLEADERS as well.
I wonder if I should reinstate the alpha choices.
John F. Uhden
メッセージ10/59
pendean
Community Legend
Community Legend
@john.uhden wrote:
@pendean ,
LOL, no, I just went down this rabbit-hole looking for something else when I stumbled across both links and remembered this post thread.
メッセージ11/59
mruPRQUJ
Thank you very much all of you. Sorry to reply to you so late as I am busy.
@john.uhden
The below is the link of the lisp,
Re: StripMText Issue - Autodesk Community - AutoCAD
Could you please advise me on how to use it? After loaded two version of the lisp, input 'cv_unformat' or 'unformat', neither of them works, thanks. 🙂
0 件のいいね
メッセージ12/59
mruPRQUJ
Sorry to reply to you so late as I am busy. The lisp works, but I wonder if it is possible to make it better. If there are several mtext with different width factor, it only can modify one group mtext with the same width factor. Is it possible to change all mtext at one time? many thanks. 🙂
0 件のいいね
メッセージ13/59
mruPRQUJ
Could you please provide your latest version to me? many thanks.
0 件のいいね
メッセージ14/59
john.uhden
@mruPRQUJ ,
Do you want the old version that let's you input what formatting to remove, or the new one that just removes all formatting?
John F. Uhden
メッセージ15/59
mruPRQUJ
Hi, Both of them is great, they can be used for different situation. If it is not possible, I prefer the latest one, thanks a million. 🙂
0 件のいいね
メッセージ16/59
john.uhden
@mruPRQUJ ,
Then you probably want an updated version of the old one because one of the key code choices is "*" which means remove all formatting.  Note that it will have to wait until I have some spare time.
John F. Uhden
0 件のいいね
メッセージ17/59
mruPRQUJ
Hi, can I have one which is available?  I can use it for some drawings, removing all formatting is ok, I can't thank you enough. 🙂
0 件のいいね
メッセージ18/59
mruPRQUJ
Can I have one which is available? Old or new one does not matter, thanks. 🙂
0 件のいいね
メッセージ19/59
john.uhden
@mruPRQUJ ,
The only version I have at hand removes all formatting, including width factors.
Do you want that?
Or would you rather wait for me to update the old version which offers a selection of key codes.
John F. Uhden
メッセージ20/59
mruPRQUJ
That one is good, removing all formatting is ok, I can use for some drawings, thanks a lot! 🙂
0 件のいいね
