strip mtext formatting
mruPRQUJ
Message 1 of 59
mruPRQUJ
Is it possible to create a lisp to strip mtext formatting? like, width factor, tracking and oblique angle. The attached lisp can strip mtext, but not formatting. Thank you very much in advance, 🙂
Replies (58)
Message 21 of 59
ronjonp
@mruPRQUJ Have you tried THIS ?
Quick test and it removed width factor:
(LM:UnFormat "adasd{\\W2.1;sa\\W1;\\Odads}" t)
;; Returns "adasdsadads"
Message 22 of 59
mruPRQUJ
I tried it, it can only strip mtext width, not width factor, thanks.
Message 23 of 59
ronjonp
Not according to my test..
Try it:
(defun c:foo (/ e)
;;-------------------=={ UnFormat String }==------------------;;
;;  Returns a string with all MText formatting codes removed. ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  str - String to Process                                   ;;
;;  mtx - MText Flag (T if string is for use in MText)        ;;
;;  Returns:  String with formatting codes removed            ;;
(defun LM:UnFormat ( str mtx / _replace rx )
    (defun _replace ( new old str )
        (vlax-put-property rx 'pattern old)
        (vlax-invoke rx 'replace str new)
    (if (setq rx (vlax-get-or-create-object "VBScript.RegExp"))
        (progn
            (setq str
                (vl-catch-all-apply
                    (function
                        (lambda ( )
                            (vlax-put-property rx 'global     actrue)
                            (vlax-put-property rx 'multiline  actrue)
                            (vlax-put-property rx 'ignorecase acfalse)
                            (foreach pair
                                    ("\032"    . "\\\\\\\\")
                                    (" "       . "\\\\P|\\n|\\t")
                                    ("$1"      . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
                                    ("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
                                    ("$1$2"    . "\\\\(\\\\S)|[\\\\](})|}")
                                    ("$1"      . "[\\\\]({)|{")
                                (setq str (_replace (car pair) (cdr pair) str))
                            (if mtx
                                (_replace "\\\\" "\032" (_replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str))
                                (_replace "\\"   "\032" str)
            (vlax-release-object rx)
            (if (null (vl-catch-all-error-p str))
                str
(vl-load-com)
  (cond	((and (setq e (car (entsel "\\nPick mtext: ")))
	      (vlax-property-available-p (setq e (vlax-ename->vla-object e)) 'textstring)
	 (vla-put-textstring e (lm:unformat (vla-get-textstring e) t))
  (princ)
Message 24 of 59
mruPRQUJ
It looks like it did not work. I may make a mistake. Please see the info below, thanks a lot!
Message 25 of 59
ronjonp
@mruPRQUJ
You have to load the code from the link I sent previously ??
Looks at the code above again I added the function. I thought I was dealing with someone more experienced with programming.
Message 26 of 59
mruPRQUJ
you mean two lisp?
Message 27 of 59
mruPRQUJ
could you please provide detail how to use it? thanks a million.
Message 28 of 59
ronjonp
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/strip-mtext-formatting/m-p/12113644#...
Message 29 of 59
mruPRQUJ
Hi, it is a little late. I will try it tomorrow, many thanks.
Message 30 of 59
ronjonp
Same here. Glad to be of your assistance. 😉
Message 31 of 59
john.uhden
@mruPRQUJ ,
OK.  Here ya go...
John F. Uhden
Message 32 of 59
ronjonp
Please tell me you got it to work...
Message 33 of 59
mruPRQUJ
It works prefect! If it can modify the block attribute, that would be better! Thanks a lot! 🙂
Message 34 of 59
mruPRQUJ
It works, I am sorry I made a mistake. It would be better if it can modify multiple objects at one time and modify block attributes as well, thanks a lot! 🙂
Message 35 of 59
B_Rainey_3366
@john.uhden
How are ya?
I found that my 2024 AutoCAD, in the MText editor, it has a "Remove Character, Paragraph or ALL Formatting" in the right-click dialog and works on selected text. But I'm sure you know this... Right?
Brian
Message 36 of 59
john.uhden
Doing fine, @B_Rainey_3366 ,
Welcome to my world.
No, I didn't know that.  We're still running Civil 3D 2020.
As to the unformatting, I wonder if they used Joe Burke's/Steve Doman's code or mine.
But I don't care.  Sounds good to me.
Of course, now someone will point out to me that it was there in 2020.  But that's the way I am.  I find out that the neighbor was pregnant when the kid has turned 2.
John F. Uhden
Message 37 of 59
EnM4st3r
i just checked in 2019 and its there. But i dont know how you would access that with lisp. Is that even possible?
Message 38 of 59
john.uhden
@EnM4st3r ,
It works in 2020 as well, though I have no idea how to invoke it via AutoLisp.
John F. Uhden
Message 39 of 59
pendean
Community Legend
Community Legend
Those selections are inside-editor options, LISP usage while in the editor is not possible.
Message 40 of 59
michellem
Hello Everyone;
Does anyone know if StripMtext has been updated recently? I tried using it on some Mtext in a cad file exported from Revit and it had problems clearing out tabs.
I added this section to the code and it seems to work (mostly) but my understanding Mtext format codes is lacking:
      ;Autocad seems to have revised the way it does tabs.
      ;I kept the old version and added this as a second pass.
      (setq str (RE:Replace "" "\\\\pxt[0-9.,]+;" str))
      (setq str (RE:Replace "" "\\\\pxqc,t[0-9.,]+;" str)) ;center tabs?
      (setq str (RE:Replace "" "\\\\pxqr,t[0-9.,]+;" str)) ;right tabs?
      str ;Return str
Sincerely;
Michelle
PS: I am looking for updated documentation of MText formatting codes for a project I am working on and would appreciate if someone can point me in the right direction.
