- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
HI
I have a little problem with the functions: ut:titel and ut:Kopie
For making them work correctly i need to select the attribute. I don't know how to make them work selecting just the block.
Please a little help...
(vl-load-com) (defun c:<Schnitt ( / *error* nVAR oVAR ent ensel BEingabe skala adoc fail) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end")) (princ (strcat "\nError: " errmsg))) (mapcar 'setvar nVAR oVAR) (if fail (alert "Schnittbezeichnungen mit verschiedenen Inhalten \n(z.B. A & 1) können nicht neu geordnet werden!")) (vla-endundomark adoc) (princ)) (defun ut:titel ( enti / att fieldcode titel pnt) (setq att (nentselp (cadr enti)) att (vlax-ename->vla-object (car att))) (setq fieldcode (strcat "%<\\AcObjProp Object\(%<\\_ObjId " (itoa (vla-get-objectid att)) ">%\).TextString>%") titel (strcat "Schnitt " fieldcode "-" fieldcode " 1:" (itoa *mstb*))) (command "_.insert" "SPI-schnitt_Text" "_s" skala "_r" 0) (while (> (getvar "cmdactive") 0)(command (setq pnt (getpoint "Einfügepunkt wählen:")) titel)) (command "_.insert" "SPI-Schnitttiteltext" pnt skala "") (command "_explode" "_l") (command "_purge" "_bl" "SPI-Schnitttiteltext" "_n") (princ (strcat "\nSchnittabhängiger Titel erstellt.")) ) (defun ut:kopie ( enti / att fieldcode titel) (setq att (nentselp (cadr enti)) att (vlax-ename->vla-object (car att))) (setq fieldcode (strcat "%<\\AcObjProp Object\(%<\\_ObjId " (itoa (vla-get-objectid att)) ">%\).TextString>%")) (command "_.-insert" "spi-schnitt-k" pause skala skala pause fieldcode fieldcode) ) (defun LM:vl-setattributevalue ( blk tag val ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (vla-put-textstring att val) val))) (vlax-invoke blk 'getattributes))) (or *mstb* (setq *mstb* 50)) (or *einhsk* (setq *einhsk* 1)) (setq skala (* (/ *mstb* 50.0) *einhsk*)) (if (not (tblsearch "block" "SPI-Schnittbezeichnungen")) (progn (command "_.insert" "SPI-Schnittbezeichnungen") (command))) (vla-endundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object)))) (vla-startundomark adoc) (setq oVAR (mapcar 'getvar (setq nVAR '(CLAYER ATTREQ ATTDIA CMDECHO)))) (setvar 'ATTREQ 1) (setvar 'ATTDIA 0) (setvar 'CMDECHO 0) (if (tblsearch "LAYER" "-I-Schnittbezeichnung") (progn (setvar "CLAYER" "-I-Schnittbezeichnung") (command "_.-LAYER" "_on" "-I-Schnittbezeichnung" "") ) (command "_.-LAYER" "_m" "-I-Schnittbezeichnung" "_co" "6" "-I-Schnittbezeichnung" "")) (while (progn (setvar 'ERRNO 0) ;; reset errno (setq ensel (entsel "\nSchnittbezeichnung wählen oder <Neue einfügen>: ")) (cond ((= 7 (getvar 'ERRNO)) nil) ;; http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-97327347-2A13-4CBC-BDBF-979C7F1CABD5 ((not ensel) nil) ((not (wcmatch (cdr (assoc 0 (entget (car ensel)))) "INSERT")) (princ "\nKeine Schnittbezeichnung gewählt!")) ((not (wcmatch (strcase (vla-get-effectivename (vlax-ename->vla-object (car ensel)))) "SPI-SCHNITT,SPI-SCHNITT-VERSETZT,SPI-SCHNITT-WINKEL")) (princ "\nKeine Schnittbezeichnung gewählt!")) (T nil)))) (if ensel (progn (setq BEingabe (strcase (getstring "\nNeue Schnittbezeichnung angeben oder [TItel/KOpie/NEuordnen]: ")) ent (car ensel)) (cond ((= BEingabe "TI")(ut:titel ensel)) ((= BEingabe "TITEL")(ut:titel ensel)) ((= BEingabe "KO")(ut:kopie ensel)) ((= BEingabe "KOPIE")(ut:kopie ensel)) ((= BEingabe "NE")(ut:ordnen)) ((= BEingabe "NEUORDNEN")(ut:ordnen)) (T (LM:vl-setattributevalue (vlax-ename->vla-object ent) "rechts" BEingabe) (LM:vl-setattributevalue (vlax-ename->vla-object ent) "links" BEingabe) (princ (strcat "\nSchnittbezeichnung auf " BEingabe "-" BEingabe " geändert."))) ) ) (progn (princ "\nEinfügepunkt angeben: ") (command "_.-insert" "spi-schnitt" pause skala skala pause (setq BEingabe (strcase (getstring "\nSchnittbezeichnung angeben: "))) BEingabe) (princ (strcat "\nSchnittbezeichnung " BEingabe "-" BEingabe " eingefügt.")) ) ) (command "_.regen") (*error* "end") (prin1) ) ; end of defun
