Can I delete AEC Objects by lisp (or other method?)
HELLO ~~ I can not bind a xref which has the AEC Objects.So I want to explode or delete the AEC objects.How can I do with LISP.
_gile
You can try with ZombieKiller.
Gilles Chanteau
GileCAD
GitHub
I also find ACAD_PROXY_ENTITY.What is that?And can I kill it too?
_gile
See the topic.
You can try to kill them (make a bakup before...)
Gilles Chanteau
GileCAD
GitHub
I already know how to explode the "AcDbZombieEntity"("ACAD_PROXY_ENTITY")  when the drawing is activated.
Here is the code.
(defun AEC-explode (/ adoc ss)
(setq ss (ssget "X" '((0 . "ACAD_PROXY_ENTITY"))))
(if ss
(progn
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
(SSSETFIRST nil ss)
(vla-sendcommand adoc "Explode\r")
(vla-sendcommand adoc "Explode p \r")
I want to do this without open the drawing.And I have know how to find "AcDbZombieEntity",but I don't know how to explode.
Here is the code.
(defun c:tt( / )
	(setq dbx (Vlax-Get-Or-Create-Object "ObjectDBX.AxDbDocument.18" ))
	(setq path "C:/")
	(foreach file (vl-directory-files path "*.dwg" 1)
		(Vlax-Invoke-Method dbx 'Open (strcat path file) )
		(vlax-for ob (Vlax-Get dbx 'ModelSpace)
			(cond
				((= "AcDbZombieEntity" (Vlax-Get ob 'ObjectName ))
					    (vla-Explode ob);;;;;;How to explode,this code is wrong.
		(Vlax-Invoke-Method dbx 'SaveAs (strcat path file))
	(vlax-release-object dbx)
_gile
vla-explode does not apply to AcDbZombieEntity, according to your first message, you should try vla-Delete (wrapping it in a (vl-catch-all-apply ...) expression.
Anyway, typically AcDbZombieEntity objects come with non graphical AcDbZombieObject (as you can see with FINDZOMBIES or KILLZOMBIES commands). Most often, these objects are dictionary entries.
Gilles Chanteau
GileCAD
GitHub
