Block in table
Block in table
Lex_van_Ham
Message 1 of 14
Block in table
Lex_van_Ham
Hello again,
One more question about tables: How do I get a block preview in a table cell.
It doesn't have to be some complicated selection thing just standard always the same block in  the same cell.
Do I just add a line of code in the cell i want it in or is this more complicated? I want it in cell 3 2.
(vla-setText table 3 0 "text")
(vla-setText table 3 1)
(   .................      3 2 )
Replies (13)
Message 2 of 14
_gile
As shown in this reply, you can do:
(vla-SetBlockTableRecordId table 3 2 blockId :vlax-true)
where blockId is the ObjectId of the block definition.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 14
Lex_van_Ham
Yeah I got that in it but I don't really know how to get the ID, can you help me with this?
(the blocks aren't drawn but are loaded with the dwt)
Message 4 of 14
Satish_Rajdev
Try this functions :
(defun set:tablerecord (tableobject row column blockname / bk fg id)
  (setq	bk (vla-item (vla-get-blocks
		       (vla-get-activedocument (vlax-get-acad-object))
		     blockname
  (if (vlax-method-applicable-p
	tableobject
	'setblocktablerecordid32
    (setq id (vla-get-objectid32 bk)
	  fg t
    (setq id (vla-get-objectid bk))
  ((if fg
     vla-setblocktablerecordid32
    tableobject	row column id :vlax-true)
Example :
(set:tablerecord table 3 2 "Specify Blockname")
Best Regards,
Satish Rajdev
REY Technologies | Linked IN | YouTube Channel
Message 5 of 14
Lex_van_Ham
Awesome thanks Smiley Happy
Message 6 of 14
_gile
Here's a way to get the ObjectId of a block which name is bound to the blockName variable.
;; get the block table (block definitions collection)
(setq blockTable (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object))))
;; get a block by name ;; (throws an error if the the block table does not contain a block names as blockName) (setq block (vla-Item blockTable blockName))
;; get the block ObjectId (setq blockId (vla-get-ObjectId block))
Maybe you want to get all block definitions in the current drawing block table:
;; build a list of dotted pairs with all block definitions and their ObjectId
(vlax-for blk blockTable
  (if (and (= (vla-get-IsLayout blk) :vlax-false)
           (= (vla-get-IsXref blk) :vlax-false)
    (setq blockList (cons (cons (vla-get-Name blk) (vla-get-ObjectId blk)) blockList))
Gilles Chanteau
GileCAD
GitHub
Message 7 of 14
Lex_van_Ham
One last thing might be a stupid question but how do I make the text in the entire table larger (within the lisp so without user input)
Message 8 of 14
_gile
This depends on the current table style settings.
Gilles Chanteau
GileCAD
GitHub
Message 9 of 14
Satish_Rajdev
I didn't understand your question, Can you please explain it with picture?
Best Regards,
Satish Rajdev
Message 10 of 14
Lex_van_Ham
When I run the script it makes the table and everything works great but the text is pretty small:
Message 11 of 14
Satish_Rajdev
Understood. You can set text height using this:
(vla-setcelltextheight table row column 1.0)
Best Regards,
Satish Rajdev
Message 12 of 14
Lex_van_Ham
Also, is there a way I can put a .PNG in the cells instead of blocks?
Message 13 of 14
_gile
You can also set the text height for the entire row:
(vla-SetTextHeight table row height)
Gilles Chanteau
GileCAD
GitHub
Message 14 of 14
_gile
To be clearer, you can set the text height bay row type:
Only data rows (bit 1)
(vla-SetTextHeight table 1 height)
Only title row (bit 2)
(vla-SetTextHeight table 2 height)
Only header row (bit 4)
 You can also combinate this, e.g. for the entire table (+ 1 2 4):
(vla-SetTextHeight table 7 height)
Gilles Chanteau
GileCAD
GitHub
