Automatic conversion of hundreds of drawings from mm to inches...?
oransen
oransen
Hello All,
Is there a program which does an automatic conversion of hundreds of drawings from mm to inches...?
Both the dimenision text and the actual objects need to be converted.
I've seen many posts of how to do it by hand on a few, but I've been asked to find if there is a good quick way for many drawings...
TheCadNoob suggested using coreconsole with some LISP or VBA code.
Any advice or suggestions?
TIA!
Look at discussion
ВeekeeCZ
Using the -DWGUNITS command you should be able to do the conversion.
The second thing is the way to apply that on all drawings. Either to use ScriptPro or suggested console....
