Script to change block layer and set to no plot
tevansHMH
Message 1 of 13
tevansHMH
I have written this script to change a block to another layer, freeze that layer and set it to noplot but it isnt working. can anyone tell me where it is broken?
;;SCRIPT TO SUBSTITUTE A BLOCK and CHANGES ITS LAYER, FREEZE AND SET TO NO PLOT
;;THE SOURCE BLOCK MAY EXIST IN MANY
;;PLACES IN THE DRAWING, ALL INSTANCES
;;WILL BE REPLACED.
;;BY TED EVANS 7-22-21
ATTDIA 0
ATTREQ 0
_-Layer
_set 0
(command"_.chprop"(ssget"_X"'((2."soffit_vent")));"" "_layer" "A-roof-vent" "")
-INSERT
"sofit_vent=s:\cad\projects\autocad\configuration\blocks\arch\soffit_vent"
0,0,0
1
0
ERASE l
(SETQ en (ENTLAST))
-LAYER
p
n
*a-roof-vent
s 0 f "*a-roof-vent"
zoom
e
ATTDIA 1
ATTREQ 1
;END ------------------------
Replies (12)
Message 2 of 13
ВeekeeCZ
It would be nice of you if you post a test drawing and the command-line listing.
Message 3 of 13
tevansHMH
here is a sample drawing attached and the command line listing
Command: _SCRIPT
Enter script file name <S:\CAD\Projects\Blackpoint\1266\Constructs\Roof.scr>: "S:\CAD\Projects\AutoCAD\Configuration\Common\Scripts\RoofVents.scr"
Command: ATTDIA
Enter new value for ATTDIA <0>: 0
Command: ATTREQ
Enter new value for ATTREQ <0>: 0
Command: _-Layer
Current layer: "BP-Footprint"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: _set
Enter layer name to make current or <select object>: 0
Command: (command"_.chprop"(ssget"_X"'((2."soffit_vent")));"" "_layer" "A-roof-vent" "")
(_> -INSERT
(_> "sofit_vent=s:\cad\projects\autocad\configuration\blocks\arch\soffit_vent"
(_> 0,0,0
(_> 1
(_> 0
(_> ERASE l
(_> (SETQ en (ENTLAST))
(_>
(_> -LAYER
(_> p
(_> n
(_> *a-roof-vent
(_> s 0 f "*a-roof-vent"
(_>
(_> zoom
(_> e
(_> ATTDIA 1
(_> ATTREQ 1
Message 4 of 13
Kent1Cooper
A semicolon is Enter in a command macro, but in a Script it "comments out" the rest of the line.  Try:
(command "_.chprop" (ssget "_X" '((2."soffit_vent"))) "" "_layer" "A-roof-vent" "")
Kent Cooper, AIA
Message 5 of 13
tevansHMH
got a little further then this
Command: _SCRIPT
Command: ATTDIA
Command: ATTREQ
Command: _-Layer
Command: (command"_.chprop"(ssget"_X"'((2."soffit_vent")))"" "_layer" "A-roof-vent" "")
_.chprop
Select objects: bad SSGET list
Select objects: -INSERT
*Invalid selection*
Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle
Message 6 of 13
Kent1Cooper
I didn't notice before, but an entity data entry with a dotted-pair list requires a space on either side of the period.  Try:
  (command"_.chprop"(ssget"_X"'((2 . "soffit_vent")))"" "_layer" "A-roof-vent" "")
[And just as a matter of visual clarity, I find it easier to "read" what's going on with spaces in other places where they may not be required:
  (command "_.chprop" (ssget "_X" '((2 . "soffit_vent"))) "" "_layer" "A-roof-vent" "")
especially where it's outright visually ambiguous as at the "' adjacency.  But some spaces are not optional.]
Kent Cooper, AIA
Message 7 of 13
tevansHMH
that fixed it except the block is not being redefined when inserted to replace the existing block. what would cause that? I modified the block so the hatch is on a different layer hoping that when inserted it would redefine the block with the update.
Message 8 of 13
Kent1Cooper
Now that what precedes that Insertion has been fixed, and it should actually be getting around to the Insert part, are you getting any message during that?
Kent Cooper, AIA
Message 9 of 13
tevansHMH
No errors or message, seems to proceed to the end.
Message 10 of 13
Kent1Cooper
When I set up a similar situation, it successfully redefined the Block, and I got the message:
Block "BlockName" redefined
[without being asked whether I want to redefine it], and before it asks for the insertion point.  I assume you are not getting that message.  What else appears at the command line in the range of the Insert operation?
Kent Cooper, AIA
Message 11 of 13
tevansHMH
Command: _SCRIPT
Command: ATTDIA
Command: ATTREQ
Command: _-Layer
Command: (command"_.chprop"(ssget"_X"'((2 ."soffit_vent")))"" "_layer" "A-roof-vent" "")
misplaced dot on input
Command: -INSERT
Enter block name or [?]: "sofit_vent=s:\cad\projects\autocad\configuration\blocks\arch\soffit_vent"
Duplicate definition of block _ArchTick ignored.
Duplicate definition of block DimArrow ignored.
Unit-scaling inserted database...
Units: Inches Conversion: 0'-1"
Specify insertion point or [Basepoint/Scale/Rotate]: 0,0,0
Specify scale factor <1>: 1
Specify rotation angle <0.00>: 0
Command: ERASE
Select objects: l
1 found
Select objects: (SETQ en (ENTLAST))
<Entity name: 26ea625fd30>
1 found (1 duplicate), 1 total
Select objects:
Command: -LAYER
Current layer: "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: p
Enter a plotting preference [Plot/No plot] <Plot>: n
Enter layer name(s) for this plot preference <0>: *a-roof-vent
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: s
Enter layer name to make current or <select object>: 0 Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: f
Enter name list of layer(s) to freeze or <select objects>: "*a-roof-vent"
Command: zoom
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: e
Command: ATTDIA
Enter new value for ATTDIA <0>: 1
Message 12 of 13
Kent1Cooper
[Could it be about the difference between one f and two ff's?]
Kent Cooper, AIA
Message 13 of 13
tevansHMH
that was it. I was close, just a few little errors. Im usually not this bad at overlooking things.
Thanks for the extra set of eyes.
