Startapp won't run seemingly due to spaces in the filepath and name
peter_thomson
peter_thomson
I want to open a spreadsheet from a button on a toolbar using lisp..
The code I have is this...
(STARTAPP "C:/Program Files (x86)/Microsoft Office/root/Office16/EXCEL.EXE" "C:/Data/AP CAD Tools/Plot/Stantec-Drawing Registry.XLSM")
Excel opens but it stumbles on the filename to open at the first space in the filepath..
Any tricks to overcome this?
Comments welcomed.
Cheers, Peter T
hak_vz
@peter_thomson  Try this
(STARTAPP "C:\\Program Files (x86)\\Microsoft Office\\root\\Office16\\EXCEL.EXE" "C:\\Data\\AP CAD Tools\\Plot\\Stantec-Drawing Registry.XLSM")
Miljenko Hatlak
pbejse
You can also consider using this
;; Open  -  Lee Mac
;; A wrapper for the 'Open' method of the Shell Object
;; target - [int/str] File, folder or ShellSpecialFolderConstants enum
(defun LM:open ( target / rtn shl )
    (if (and (or (= 'int (type target)) (setq target (findfile target)))
             (setq shl (vla-getinterfaceobject (vlax-get-acad-object) "shell.application"))
        (progn
            (setq rtn (vl-catch-all-apply 'vlax-invoke (list shl 'open target)))
            (vlax-release-object shl)
            (if (vl-catch-all-error-p rtn)
                (prompt (vl-catch-all-error-message rtn))
                t
(LM:Open "C:/Data/AP CAD Tools/Plot/Stantec-Drawing Registry.XLSM")
(LM:Open "C:\\Data\\AP CAD Tools\\Plot\\Stantec-Drawing Registry.XLSM")
HTH
hak_vz
You can also test this method.
(STARTAPP "EXPLORER" "C:\\Data\\AP CAD Tools\\Plot\\Stantec-Drawing Registry.XLSM")
 In this case Windows Explorer will start application that is associated with file extension or offer to select one to use.
Miljenko Hatlak
john.uhden
Because of spaces, I think you need to put the target in double quotes...
""C:/Data/AP CAD Tools/Plot/Stantec-Drawing Registry.XLSM""
   maybe even like this...
"\"C:/Data/AP CAD Tools/Plot/Stantec-Drawing Registry.XLSM\""
John F. Uhden
peter_thomson
Thank you.
I should have looked at Lee Mac's site before I asked.
peter_thomson
Thank you all for your responses.
After posting my question, I searched this forum and found an answer.
It is all about adding extra quotes, like this...
(startapp "C:/Program Files (x86)/Microsoft Office/root/Office16/EXCEL.EXE" (STRCAT "\"" "C:/Data/AP CAD Tools/Plot/Stantec-Drawing Registry.XLSM" "\""))
and it worked a treat.
Onward and Upward..
Cheers
