cut layer to 1m to the next layer
Fleww
Fleww
Hi, can you please help me, I need lisp to cut layer Garden Trench(green one) to the layer Trench(blue one), to make it to the final look like red one - 1m lenght from the layer Trench. Its big drawings so its so annoying to do it manual. Please help
ВeekeeCZ
You can use this routine for multiple LENGTHEN. Start/Total/1
Then remove the un-touching rest. It should not take that long.
(vl-load-com)
(defun c:LengthenAdvanced ( / *error osm* s i e l f) ; Specifice od ktereho konce nebo středu
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if osm (setvar 'OSMODE osm))
    (princ))
  (if (and (setq s (ssget "_:L" '((0 . "LINE,LWPOLYLINE,ARC"))))
	   (setq osm (getvar 'osmode))
	   (setvar 'osmode 0)
	   (or *la-opt1* (setq *la-opt1* "Middle"))
	   (not (initget "Start Middle End"))
	   (setq *la-opt1* (cond ((getkword (strcat "\nApply changes from [Start/Middle/End] <" *la-opt1* ">: ")))
				 (*la-opt1*)))
	   (or *la-opt2* (setq *la-opt2* "Total"))
	   (not (initget "Delta Percent Total"))
	   (setq *la-opt2* (cond ((getkword (strcat "\nSpecify type of change [Delta/Percent/Total] <" *la-opt2* ">: ")))
				 (*la-opt2*)))
	   (cond ((= *la-opt2* "Delta")
		  (or *la-delta* (setq *la-delta* 1.))
		  (setq *la-delta* (cond ((getdist (strcat "\nEnter delta length <" (rtos *la-delta*) ">: ")))
					 (*la-delta*))))
		 ((= *la-opt2* "Percent")
		  (or *la-percent* (setq *la-percent* 100.))
		  (setq *la-percent* (cond ((getreal (strcat "\nEnter percentage length <" (rtos *la-percent*) ">: ")))
					   (*la-percent*))))
		 ((= *la-opt2* "Total")
		  (or *la-total* (setq *la-total* 1.))
		  (setq *la-total* (cond ((getdist (strcat "\nSpecify total length <" (rtos *la-total*) ">: ")))
					 (*la-total*)))))
    (if (/= *la-opt1* "Middle")
      (progn
	(cond ((= *la-opt2* "Delta")	(command "_.lengthen" "_delta" *la-delta*))
	      ((= *la-opt2* "Percent")	(command "_.lengthen" "_percent" *la-percent*))
	      ((= *la-opt2* "Total")	(command "_.lengthen" "_total" *la-total*)))
	(repeat (setq i (sslength s))
	  (setq e (ssname s (setq i (1- i))))
	  (cond ((= *la-opt1* "Start")	(command (list e (vlax-curve-getpointatparam e (vlax-curve-getstartparam e)))))
		((= *la-opt1* "End")	(command (list e (vlax-curve-getpointatparam e (vlax-curve-getendparam e)))))))
	(if (> (getvar 'cmdactive) 0) (command "")))
      (if (= *la-opt2* "Delta")
	(progn
	  (command "_.lengthen" "_delta" (/ *la-delta* 2))
	(repeat (setq i (sslength s))   ;; Middle Percent and Total
		l (vlax-curve-getdistatparam e (vlax-curve-getendparam e))
		f (if (= *la-opt2* "Percent") (* l *la-percent* 0.01) *la-total*))
	  (command "_.lengthen" "_delta" (/ (- f l) 2)
  (*error* "end")
Fleww
Thank you so much! ❤️ perfect
Sea-Haven
Not sure image not zoomed in you want a 1m red line at end of green line, ie my way maybe trim green lines by offsetting blue 1m using ssget "F" can trim out all the green lines, at same time remember all green line end points 1st so just after trim add a red line. Maybe easier method.
