You can use this routine for multiple LENGTHEN. Start/Total/1
Then remove the un-touching rest. It should not take that long.
(vl-load-com)
(defun c:LengthenAdvanced ( / *error osm* s i e l f) ; Specifice od ktereho konce nebo středu
(defun *error* (errmsg)
(if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
(princ (strcat "\nError: " errmsg)))
(if osm (setvar 'OSMODE osm))
(princ))
(if (and (setq s (ssget "_:L" '((0 . "LINE,LWPOLYLINE,ARC"))))
(setq osm (getvar 'osmode))
(setvar 'osmode 0)
(or *la-opt1* (setq *la-opt1* "Middle"))
(not (initget "Start Middle End"))
(setq *la-opt1* (cond ((getkword (strcat "\nApply changes from [Start/Middle/End] <" *la-opt1* ">: ")))
(*la-opt1*)))
(or *la-opt2* (setq *la-opt2* "Total"))
(not (initget "Delta Percent Total"))
(setq *la-opt2* (cond ((getkword (strcat "\nSpecify type of change [Delta/Percent/Total] <" *la-opt2* ">: ")))
(*la-opt2*)))
(cond ((= *la-opt2* "Delta")
(or *la-delta* (setq *la-delta* 1.))
(setq *la-delta* (cond ((getdist (strcat "\nEnter delta length <" (rtos *la-delta*) ">: ")))
(*la-delta*))))
((= *la-opt2* "Percent")
(or *la-percent* (setq *la-percent* 100.))
(setq *la-percent* (cond ((getreal (strcat "\nEnter percentage length <" (rtos *la-percent*) ">: ")))
(*la-percent*))))
((= *la-opt2* "Total")
(or *la-total* (setq *la-total* 1.))
(setq *la-total* (cond ((getdist (strcat "\nSpecify total length <" (rtos *la-total*) ">: ")))
(*la-total*)))))
(if (/= *la-opt1* "Middle")
(progn
(cond ((= *la-opt2* "Delta") (command "_.lengthen" "_delta" *la-delta*))
((= *la-opt2* "Percent") (command "_.lengthen" "_percent" *la-percent*))
((= *la-opt2* "Total") (command "_.lengthen" "_total" *la-total*)))
(repeat (setq i (sslength s))
(setq e (ssname s (setq i (1- i))))
(cond ((= *la-opt1* "Start") (command (list e (vlax-curve-getpointatparam e (vlax-curve-getstartparam e)))))
((= *la-opt1* "End") (command (list e (vlax-curve-getpointatparam e (vlax-curve-getendparam e)))))))
(if (> (getvar 'cmdactive) 0) (command "")))
(if (= *la-opt2* "Delta")
(progn
(command "_.lengthen" "_delta" (/ *la-delta* 2))
(repeat (setq i (sslength s)) ;; Middle Percent and Total
l (vlax-curve-getdistatparam e (vlax-curve-getendparam e))
f (if (= *la-opt2* "Percent") (* l *la-percent* 0.01) *la-total*))
(command "_.lengthen" "_delta" (/ (- f l) 2)
(*error* "end")
