Required a lsp to make automatic topo survey by creating layer point text from one excel
sdhara.hit
Message 1 of 29
sdhara.hit
Required a autocad lsp that can create text and point from excel file also make sure that text & point will be in same layer as text value or mention layer name. also need to crate that layer name from excel. Its to make automatic topo survey.
Replies (28)
Message 21 of 29
autoid374ceb4990
What exactly does "2d topo survey" look like?  The data you posted has no elevation data. If you just want 2D points drawn that should be no problem.
Message 22 of 29
pendean
Community Legend
Community Legend
@sdhara.hit wrote:
Its too much high level thinking....
Message 23 of 29
diagodose2009
Using Excel directly,  is very hard, because today exists too many version CAD program/s (Cadian, AutoCad, TurboCad) and parser coordinates from *excel to Drawing.CAd.; is too hard for everyone.
Only AutoCAd have between 70...100 versions Acad, and compatibility with MsExcel
is bad-lock for All.
M/r. sdhara.hit do not need import Excel .coo to Drawing, and extend Excel function/s
with  surveyour's hi-tech-function/s.
 [code]
My solution I can parser Excel coordinates files as profesionally surveyour, for she.
https://youtu.be/hrW-o7Ln4EA
https://youtu.be/AyqJf8csmXk
If she need, then she send PM tom me, perhaps together can research our'solutions.
[/code]
Message 24 of 29
autoid374ceb4990
If the OP has Excel the XLS file can be saved as a CSV (comma delimited) file to be read easily by a LISP program.  Also the coordinate file the OP posted contains layer names with a space.  I am using a really old version of AutoCAD (R14) and spaces are not allowed in layer names, perhaps this is not true in later versions??
diagodose2009i: how do you calculate volumes with no Z coordinates?
Message 25 of 29
john.uhden
@autoid374ceb4990 ,
I think Excel provides the choice of a tab or a comma as a delimiter when creating a .CSV, so not to worry about spaces.
John F. Uhden
Message 26 of 29
Sea-Haven
Ok simplest way is read Excel direct, then insert a block with attributes, easy done.
Again post a Excel we should not have to dummy up data for testing.
What to you want at insertion point, a "Point" a "X" etc.
Message 27 of 29
sdhara.hit
How can I delete this post? I want to draw just point. but from excel . with same layer define in excel in AutoCAD.
To write an AutoCAD LISP program that draws points from Excel and ensures the points are placed on the same layer as described in the Excel file, you can follow these steps. This involves reading data from an Excel file, extracting point coordinates and layer information, and then drawing points on the specified layers in AutoCAD.
First, ensure you have the required Excel file. The file should have the coordinates and layer information in columns. For example, let's assume the Excel file has the following columns:
  • X: X-coordinate of the point
  • Y: Y-coordinate of the point
  • Z: Z-coordinate of the point (optional, can be set to 0 if not used)
  • Layer: Layer name for the point
Here's the LISP program to achieve this:
lisp
Copy code
(defun c:DrawPointsFromExcel ()
;; Function to read data from Excel and draw points in AutoCAD
(defun ReadExcelData (filePath / excelApp workbook worksheet rows data)
(setq excelApp (vlax-get-or-create-object "Excel.Application"))
(vlax-put-property excelApp 'Visible :vlax-false)
(setq workbook (vlax-invoke-method excelApp 'Workbooks 'Open filePath))
(setq worksheet (vlax-get-property workbook 'ActiveSheet))
(setq rows (vlax-get-property worksheet 'UsedRange))
(setq data (vlax-get-property rows 'Value2))
(vlax-invoke-method workbook 'Close :vlax-false)
(vlax-release-object workbook)
(vlax-release-object excelApp)
data
;; Function to draw a point in AutoCAD
(defun DrawPoint (x y z layerName)
(command "._-LAYER" "M" layerName "")
(setvar "clayer" layerName)
(command "._POINT" (list x y z))
;; Main function to read Excel data and draw points
(defun DrawPointsFromExcelMain ()
(setq filePath (getfiled "Select Excel File" "" "xlsx;xls" 0))
(if filePath
(progn
(setq excelData (ReadExcelData filePath))
;; Assuming the first row is headers, so start from the second row
(setq rowCount (length excelData))
(setq i 2)
(while (<= i rowCount)
(setq row (nth (1- i) excelData))
(setq x (atof (nth 0 row)))
(setq y (atof (nth 1 row)))
(setq z (atof (nth 2 row)))
(setq layerName (nth 3 row))
(DrawPoint x y z layerName)
(setq i (1+ i))
(princ)
;; Execute the main function
(DrawPointsFromExcelMain)
(princ)
How to Use the LISP Program
  1. Save the LISP code above into a file with the .lsp extension, e.g., DrawPointsFromExcel.lsp.
  2. Open AutoCAD.
  3. Load the LISP program using the APPLOAD command.
  4. Run the program by typing DrawPointsFromExcel in the command line.
  5. Select the Excel file when prompted.
But chat gpt lsp code not working.
Message 28 of 29
sdhara.hit
sample excel
Message 29 of 29
autoid374ceb4990
So now your Excel file does not have point names?
I have an old LISP program that I wrote many years ago that will read your file, but you would have to save the XLS file as a CSV ( space delimited text file) for it to work.  Send me a private message if you are interested.
