vla-put-AttachmentPoint
dvertz
dvertz
Once again, I'm stuck.
I am trying to set the justification on MTEXT.
So I created the mtext with "vla-AddMtext" and assigned it to the variable "VLA:OBJECT".
Then I assign (setq INT:JUSTIFY 5)
But using this code "(vla-put-AttachmentPoint VLA:OBJECT INT:JUSTIFY)" I get "; error: ActiveX Server returned the error: unknown name: AttachmentPoint".
According to the help file at: https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-FD7EDA56-7FA0-4616-A746-9B97AE0C6456
"AttachmentPoint" is the correct name for the property.
So I did a "(dumpallproperties (car (entsel)))" and this returns "Attachment (type: AcDbMText::AttachmentPoint) (LocalName: Justify) = 1".
So, if I assume that "Attachment" is really the correct property and use "(vla-put-Attachment VLA:OBJECT INT:JUSTIFY)" then I get "; error: no function definition: VLA-PUT-ATTACHMENT".
So, how do I "put" the justification on MTEXT?
Civil 3D 2022,
Windows 10 Pro, x64, Nvidia Quadro P1000
Intel Core i9-11900k; 3.50GHz, 32 GB RAM, 500GB WD BLACK M.2
komondormrex
try that way
(vla-put-attachmentpoint VLA:OBJECT  INT:JUSTIFY)
dvertz
Thanks for the suggestion. The only difference I saw was capitalization. I was sure that wouldn't be the issue, but I tried it anyway. It responds with the exact same error (capitalization and all).
Civil 3D 2022,
Moshe-A
@dvertz hi,
Make sure you do not have any restrictions for that mtext like you putting it on locked layer?!
i give it a try (on R2022) on model space and it worked also inside a block and it worked.
Moshe
komondormrex
capitalization has no difference, but consider attachment vs attachmentpoint.
paullimapa
don't mix vl obj terms with lisp terms...sometimes they're the same other times they're not
for example use the following method to get vl dump:
(vlax-dump-object (setq obj (vlax-ename->vla-object (car(entsel)))))
Then the following should return current setting:
(vla-get-attachmentpoint obj)
 To change use what you've shown:
(vla-put-attachmentpoint obj 5)
Then the lisp dump method is as you've shown:
(dumpallproperties (setq en(car(entsel))))
Then use the following to get the value:
(getpropertyvalue en "attachment")
Then the following to set the value:
(setpropertyvalue en "attachment" 5)
Supported values for MTEXT are:
 1 = acTopLeft 2 = acTopCenter 3 = acTopRight
 4 = acMiddleLeft 5 = acMiddleCenter 6 = acMiddleRight
 7 = acBottomLeft 8 = acBottomCenter 9 = acBottomRight
Paul Li
IT Specialist
@The Office
Kent1Cooper
But using this code "(vla-put-AttachmentPoint VLA:OBJECT INT:JUSTIFY)" I get "; error: ActiveX Server returned the error: unknown name: AttachmentPoint". ....
That format works for me.  So does this, which you might try instead:
(vlax-put-property VLA:OBJECT 'attachmentpoint INT:JUSTIFY)
If that doesn't work either, I don't know what to suggest.  The locked-layer possibility can't be it, because if that's the problem, the error message is specific about it.
Kent Cooper, AIA
