I'm trying to set a property of a dynamic block on insertion, stretching a wipeout to match the characters in an attribute. I'm using Lee Mac's LM:setdynpropvalue function which is working perfectly in every other LISP I've used it in, so I must assume I'm sending something wrong to the function.
I've made the parameter a property in the block table, and it works fine when inserted using the insert command (though it doesn't auto-adjust the property in that use).
The relevant code is below, the full code and the block is attached. The error message is {unknown name: "GETDYNAMICBLOCKPROPERTIES" }.
Thanks for any help, I've been going over this for days
Gorra
