replacement for dos_filedate
HE-MJJ
1,800件の閲覧回数
25件の返信
メッセージ1/26
HE-MJJ
I'm trying find a replacement for dos_filedate.
I thought by using vl-file-systime, but vl-file-systime apparently does not return a value of a file that is opened which dos_filedate does. As you can see in results below:
_$ (vl-file-systime "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022A.dwg")
nil
_$ (vl-file-systime "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022.dwg")
(2024 3 5 15 12 31 56 0)
_$ (dos_filedate "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022A.dwg")
(("0000_BT-BB-022A.dwg" . 2.02404e+07))
_$
Does anyone know a working alternative for dos_filedate to obtain the date of an opened drawing?
0 件のいいね
1,801件の閲覧回数
25件の返信
返信 (25)
メッセージ2/26
paullimapa
Perhaps try code on this thread
Paul Li
IT Specialist
@The Office
0 件のいいね
メッセージ3/26
EnM4st3r
try this:
  (if (not jtod) (load "Julian.lsp"))
  (jtod (getvar "tdupdate"))
0 件のいいね
メッセージ4/26
HE-MJJ
Thanks. Not sure if I already tried this. I need it to work under AutoCAD LT. I will try to figure it out...
0 件のいいね
メッセージ5/26
HE-MJJ
0 件のいいね
メッセージ6/26
paullimapa
Then it won’t work since LT lisp doesn’t support this function  vlax-create-object which is required to run that code
Paul Li
IT Specialist
@The Office
0 件のいいね
メッセージ7/26
EnM4st3r
julain.lsp is from express tools. it does not use vlax-create-object so it should work. Though idk if you have access to them
0 件のいいね
メッセージ8/26
HE-MJJ
That is too bad. I like to think in possibilities ; )
0 件のいいね
メッセージ9/26
paullimapa
Unfortunately no express tools for LT either
Paul Li
IT Specialist
@The Office
0 件のいいね
メッセージ10/26
HE-MJJ
I have Julian.lsp but afaik it cannot be use to obtain the date of a file. Correct me if I'm wrong.
0 件のいいね
メッセージ11/26
EnM4st3r
you can use it to convert the time you get in Juilan format for example (getvar "TDUPDATE") wich gives you the last updated time.
Watch my first answer.
0 件のいいね
メッセージ12/26
EnM4st3r
i mean its just basic calculations. Though im not sure if we are allowed to just post that code.
0 件のいいね
メッセージ13/26
EnM4st3r
here try this. Since you said you have Julian.lsp it should work.
(defun c:timetest (/ date dateStr)
  (CurDate (jtod (getvar "TDUPDATE")) nil)
; Returns or outputs the current date and time
; time = coded decimal time format (like you get from CDATE)
; bOutput = T - Output the string to the Command prompt
; bOutput = nil - Return a string in the MM/DD/YYYY  HH:MM:SS format
; Usage: (CurDate T)
; Usage: (CurDate nil)
(defun CurDate (time bOuput / date_val YYYY M D HH MM SS)
  ; Get the current date/time
  (setq date_val (rtos time 2 6))
  ; Break up the string into its separate date and time parts
  (setq YYYY (substr date_val 1 4)
        M    (substr date_val 5 2)
        D    (substr date_val 7 2)
        HH   (substr date_val 10 2)
        MM   (substr date_val 12 2)
        SS   (substr date_val 14 2)
  ; Output the current date and time to the Command
  ; prompt or return the formatted output as a string
  (if bOuput
    (progn
      (prompt (strcat "\nDate: " M "/" D "/" YYYY
                      "\nTime: " HH ":" MM ":" SS
      (princ)
    (strcat M "/" D "/" YYYY "  " HH ":" MM ":" SS)
0 件のいいね
メッセージ14/26
HE-MJJ
Ah! I see what you mean. Maybe I can use this in a different approach. Thanks.
0 件のいいね
メッセージ15/26
HE-MJJ
I'm picking up on this subject again and I'm running into some issues...
For example: I have this file:
(setq fnm-d (vl-file-systime "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022.dwg"))
Results in: (2024 3 5 15 12 31 56 0)
Hours is 12 and according to above properties it is 11. So I guess daylight savings time is not taken into account.
But that's not so much the problem. The date is more important for me.
(dtoj 20240315) results in: 2.46038e+06 But reversed: (jtod 2.46038e+06) results in 2.02403e+07
Why is this? Do I use wrong input?
0 件のいいね
メッセージ16/26
HE-MJJ
CDATE = 20240605.11173200 (read only)
_$ (dtoj 20240605.11173200)
2.46047e+06
_$ (jtod 2.46047e+06)
2.02406e+07
Not? 20240605.11173200
0 件のいいね
メッセージ17/26
EnM4st3r
this is just the written output in the commandline, the value is actually the same.
you can try this for example and will see its equal:
(setq cdate 20240605.11173200)
(equal cdate (jtod (dtoj cdate)) 0.001)
0 件のいいね
メッセージ18/26
EnM4st3r
so if you print it to the commandline using for example rtos it will give out the actual result with your given precision
(rtos (jtod (dtoj 20240315)) 2 6)
0 件のいいね
メッセージ19/26
HE-MJJ
I seem to be almost there...
This is my replacement for dos_filedate so far:
(defun dos-filedate (fnm / fnm-d fnm-d-j )
(if (setq fnm-d (vl-file-systime fnm))
(progn
(setq fnm-d-j (dtoj (atoi (strcat (rtos (nth 0 fnm-d) 2 0) (strnr (rtos (nth 1 fnm-d) 2 0) 2) (strnr (rtos (nth 3 fnm-d) 2 0) 2))))) ; Check: (rtos (jtod fnm-d-j) 2 6)
(setq fnm (list (cons (strcat (nth 2 (dos-splitpath fnm)) (nth 3 (dos-splitpath fnm))) fnm-d-j)))
(if (= (strcase (strcat (getvar "dwgprefix") (getvar "dwgname"))) (strcase fnm)) ; Bij dit geopende bestand
(progn
(setq fnm-d-j (getvar "tdupdate")) ; Check: (rtos (jtod fnm-d-j) 2 6)
fnm
If I check my code by replacing - for _ in dos_filedate
; form dos_filedate loaded * original doslib command *
_$
_1_$
(("0000_BT-BB-022.dwg" . 2.02403e+07))
_1_$
_1_$
_$
; form dos-filedate loaded
_$
_1_$
(("0000_BT-BB-022.DWG" . 2.46038e+06))
_1_$
(("0000_BT-BB-022A.DWG" . 2.46041e+06))
_1_$
_$
This results in these different dates:
Can you see where I'm ging wrong in the code?
(strnr is used to add 0 when strlen is 1)
0 件のいいね
メッセージ20/26
HE-MJJ
Almost got it:
Corrected the code and this is now correct:
Exept no time. What is the cause of that?
0 件のいいね
