TORIENT alternative
TORIENT alternative
shane.plunkett
TORIENT alternative
shane.plunkett
Hi, My company recently changed from Civils 3D to Autocad LT, A few changes but one we have come across that will take a bit of extra time is the loss of the Text Orient tool. Is there an alternative that can be used on Autocad LT?
pendean
Community Legend
Community Legend
Which feature do you use the most,  like just needing your text/attributes to always be "right way up" so to speak all the time?
Or do you use is most often to align those elements with angular lines etc.?
paullimapa
I assume you are on LT 2024 then try this code found on this thread
Paul Li
IT Specialist
@The Office
shane.plunkett
We regularly align text with angular lines
hak_vz
@shane.plunkett
Try this. Select one or more text or mtext entities, and pick an entity to align with. Code is looking for a nearest point at that entity at the place of selection, and looks for a point that is very near to that one. It than rotates all selected entities in that direction. If for some reason you need text entities to be rotated in 180° to opposite direction answer "y" . As alignment object you can use practically any geometric object (line polyline circle rectangle.....)
I hope this wil work in LT version, I can not test it myself.
(defun c:alt ( / ss e pt1 pt2 di i again)
	(princ "\nSelect text/mtext to realign > ")
	(setq ss (ssget '((0 . "*TEXT"))) i -1)
	(cond
		((and ss (>= (sslength ss) 1))
			(setq e (entsel "\nSelect entity to align with >" ))
			(cond
				((and e)
					(setq
						pt1 (cadr e)
						e (car e)
						e (vlax-ename->vla-object e)
						pt1 (vlax-curve-getclosestpointto e pt1)
						di (+ 0.01 (vlax-curve-getdistatpoint e pt1))
						pt2 (vlax-curve-getpointatdist e di)
					(while (<(setq i (1+ i))(sslength ss))
						(setq e (vlax-ename->vla-object (ssname ss i)))
						(vlax-put e 'rotation (angle (trans pt1 1 0)(trans pt2 1 0)))
					(initget 1 "y n")
					(setq again (strcase (getkword "\nRotate to opposite direction <y/n>? ")) i -1)
					(if (= again "Y")
							(vlax-put e 'rotation (angle (trans pt2 1 0)(trans pt1 1 0)))
				(T (princ "\nYou didn't select an object to align with!"))
		(T (princ "\nYou didn't select any text object to realign!"))
	(princ "\nDone!")
	(princ)
Miljenko Hatlak
dlbsurveysuk
Lee Mac has this https://www.lee-mac.com/dtcurve.html as well as other text alignment routines.
Attached -
Modified dtcurve to continuously loop.
Original torient routine.
Komondormrex 2024 torient routine.
