replacement for dos_filedate
HE-MJJ
Message 1 of 26
HE-MJJ
I'm trying find a replacement for dos_filedate.
I thought by using vl-file-systime, but vl-file-systime apparently does not return a value of a file that is opened which dos_filedate does. As you can see in results below:
_$ (vl-file-systime "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022A.dwg")
nil
_$ (vl-file-systime "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022.dwg")
(2024 3 5 15 12 31 56 0)
_$ (dos_filedate "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022A.dwg")
(("0000_BT-BB-022A.dwg" . 2.02404e+07))
_$
Does anyone know a working alternative for dos_filedate to obtain the date of an opened drawing?
Replies (25)
Message 2 of 26
paullimapa
Perhaps try code on this thread
Paul Li
IT Specialist
@The Office
Message 3 of 26
EnM4st3r
try this:
  (if (not jtod) (load "Julian.lsp"))
  (jtod (getvar "tdupdate"))
Message 4 of 26
HE-MJJ
Thanks. Not sure if I already tried this. I need it to work under AutoCAD LT. I will try to figure it out...
Message 5 of 26
HE-MJJ
Message 6 of 26
paullimapa
Then it won’t work since LT lisp doesn’t support this function  vlax-create-object which is required to run that code
Paul Li
IT Specialist
@The Office
Message 7 of 26
EnM4st3r
julain.lsp is from express tools. it does not use vlax-create-object so it should work. Though idk if you have access to them
Message 8 of 26
HE-MJJ
That is too bad. I like to think in possibilities ; )
Message 9 of 26
paullimapa
Unfortunately no express tools for LT either
Paul Li
IT Specialist
@The Office
Message 10 of 26
HE-MJJ
I have Julian.lsp but afaik it cannot be use to obtain the date of a file. Correct me if I'm wrong.
Message 11 of 26
EnM4st3r
you can use it to convert the time you get in Juilan format for example (getvar "TDUPDATE") wich gives you the last updated time.
Watch my first answer.
Message 12 of 26
EnM4st3r
i mean its just basic calculations. Though im not sure if we are allowed to just post that code.
Message 13 of 26
EnM4st3r
here try this. Since you said you have Julian.lsp it should work.
(defun c:timetest (/ date dateStr)
  (CurDate (jtod (getvar "TDUPDATE")) nil)
; Returns or outputs the current date and time
; time = coded decimal time format (like you get from CDATE)
; bOutput = T - Output the string to the Command prompt
; bOutput = nil - Return a string in the MM/DD/YYYY  HH:MM:SS format
; Usage: (CurDate T)
; Usage: (CurDate nil)
(defun CurDate (time bOuput / date_val YYYY M D HH MM SS)
  ; Get the current date/time
  (setq date_val (rtos time 2 6))
  ; Break up the string into its separate date and time parts
  (setq YYYY (substr date_val 1 4)
        M    (substr date_val 5 2)
        D    (substr date_val 7 2)
        HH   (substr date_val 10 2)
        MM   (substr date_val 12 2)
        SS   (substr date_val 14 2)
  ; Output the current date and time to the Command
  ; prompt or return the formatted output as a string
  (if bOuput
    (progn
      (prompt (strcat "\nDate: " M "/" D "/" YYYY
                      "\nTime: " HH ":" MM ":" SS
      (princ)
    (strcat M "/" D "/" YYYY "  " HH ":" MM ":" SS)
Message 14 of 26
HE-MJJ
Ah! I see what you mean. Maybe I can use this in a different approach. Thanks.
Message 15 of 26
HE-MJJ
I'm picking up on this subject again and I'm running into some issues...
For example: I have this file:
(setq fnm-d (vl-file-systime "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022.dwg"))
Results in: (2024 3 5 15 12 31 56 0)
Hours is 12 and according to above properties it is 11. So I guess daylight savings time is not taken into account.
But that's not so much the problem. The date is more important for me.
(dtoj 20240315) results in: 2.46038e+06 But reversed: (jtod 2.46038e+06) results in 2.02403e+07
Why is this? Do I use wrong input?
Message 16 of 26
HE-MJJ
CDATE = 20240605.11173200 (read only)
_$ (dtoj 20240605.11173200)
2.46047e+06
_$ (jtod 2.46047e+06)
2.02406e+07
Not? 20240605.11173200
Message 17 of 26
EnM4st3r
this is just the written output in the commandline, the value is actually the same.
you can try this for example and will see its equal:
(setq cdate 20240605.11173200)
(equal cdate (jtod (dtoj cdate)) 0.001)
Message 18 of 26
EnM4st3r
so if you print it to the commandline using for example rtos it will give out the actual result with your given precision
(rtos (jtod (dtoj 20240315)) 2 6)
Message 19 of 26
HE-MJJ
I seem to be almost there...
This is my replacement for dos_filedate so far:
(defun dos-filedate (fnm / fnm-d fnm-d-j )
(if (setq fnm-d (vl-file-systime fnm))
(progn
(setq fnm-d-j (dtoj (atoi (strcat (rtos (nth 0 fnm-d) 2 0) (strnr (rtos (nth 1 fnm-d) 2 0) 2) (strnr (rtos (nth 3 fnm-d) 2 0) 2))))) ; Check: (rtos (jtod fnm-d-j) 2 6)
(setq fnm (list (cons (strcat (nth 2 (dos-splitpath fnm)) (nth 3 (dos-splitpath fnm))) fnm-d-j)))
(if (= (strcase (strcat (getvar "dwgprefix") (getvar "dwgname"))) (strcase fnm)) ; Bij dit geopende bestand
(progn
(setq fnm-d-j (getvar "tdupdate")) ; Check: (rtos (jtod fnm-d-j) 2 6)
fnm
If I check my code by replacing - for _ in dos_filedate
; form dos_filedate loaded * original doslib command *
_$
_1_$
(("0000_BT-BB-022.dwg" . 2.02403e+07))
_1_$
_1_$
_$
; form dos-filedate loaded
_$
_1_$
(("0000_BT-BB-022.DWG" . 2.46038e+06))
_1_$
(("0000_BT-BB-022A.DWG" . 2.46041e+06))
_1_$
_$
This results in these different dates:
Can you see where I'm ging wrong in the code?
(strnr is used to add 0 when strlen is 1)
Message 20 of 26
HE-MJJ
Almost got it:
Corrected the code and this is now correct:
Exept no time. What is the cause of that?
