Replace-text-to-filename but have some changes!
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/replace-text-to-filename-problem/td-...
Dear All,
I found the lisp for the replace-text-to-filename but I want some changes for my convenience.
For example, Filename is: 632365-01-10 0870 15D12 Nam. I want my text will be changed to 632365-0a only (After dash will be changed to 0a.
Thank you,
Moza
pbejse
The Oa suffix is always that? or the "0" and "a" represents something else like revisions and changes from time to time?
@pbejse
The Oa suffix is always that, Fixed value!
Thank you,
Moza
pbejse
@Anonymous wrote:
@pbejse
Thank you,
Moza
Replace this line from the original post
(setq aa (strcat (vl-filename-base (getvar 'DwgName)) ".dwg"))
With this
(setq aa (strcat (substr (vl-filename-base (getvar 'DwgName)) 1 7) "0a" ".dwg"))
That is if the number of characters .i.e 632365-01-10 0870 15D12 is consistent.
It is great! Thank you very much!
pbejse
Anytime moza.
Cheers
