Replace Text to filename problem...
danglar
danglar
This Aleksandr Smirnov (ASMI) program can copy the filename of drawing to Text, MText, Tables, Dimensions and Attributes
In Multiple modes with option to insert file name of drawing as regular text (added by me).
Program working properly but a little “dirty”. I mean we have here at least 2 unnecessary steps. First – insert filename as text into the drawing as regular text entity.. After what we can copy this text and paste it in multiple mode (replace Text, MText, Tables, Dimensions and Attributes to filename of drawing)
and Second unnecessary step – delete inserted text with filename (see attached lisp)
Is it possible to eliminate these two unnecessary steps in order to select Text, MText, Tables, Dimensions and Attributes and replace it immediately to file name?
Any help will be very appreciated
i think this lisp similar you need:
(defun c:test ()
(if (setq txt_1 (car (nentsel "\n Select text,mtex,dim,attribute 1: ")))
(progn
(setq vla_1 (vlax-ename->vla-object txt_1))
(while (setq txt_2 (car (nentsel "\n Select text,mtex,dim,attribute 2: ")))
(setq vla_2 (vlax-ename->vla-object txt_2))
(vla-put-textstring vla_2 (vla-get-textstring vla_1))
(vla-regen (vla-get-activedocument (vlax-get-acad-object)) acAllViewports)
danglar
Thanks for replay
Unfortunately it’s not exactly what I need
I need to Replace Text to filename in a same way your program work
Can you modify your program?
danglar
.. another "dirty" modification.
same problem, but from another point of view
(defun c:tt ()
(setq aa (strcat (vl-filename-base (getvar 'DwgName)) ".dwg"))
(command "-style" "temp" "arial.ttf" "" "" "" "" "")
(command "_.TEXT" "s" "temp" (getpoint) 2 0 aa)
(progn
(command "erase" "l" "")
Hi, maybe this code:
(defun c:tt ()
(while (setq txt (car (nentsel "\n Select text,mtex,dim,attribute: ")))
(setq vla_obj (vlax-ename->vla-object txt))
(vla-put-textstring vla_obj aa)
danglar
Wow! It's Perfect!
This is exactly what I need.
Thank you
You are welcome.!
^_^
