@john.uhden wrote:
A bottle of Walker Black to anyone who can programmatically convert a straight polyline segment to one having only one radius, which is less than half the chord. No, you may not add vertices.
Since a single arc cannot be created between two points with a radius less than half the distance between the two points the answer to the question must lie in a closer examination of the question wording. It is noted that the word "arc" never appears in the question. A look at the DXF codes for a "polyline" indicate the possibility that perhaps a solution may be possible if a spline fit was considered but what would that imply about a radius? Still, no solution in site. We could then turn to the bottle of Walker Black. Ah, I think there's where the solution lies! Consuming the bottle would make all things possible. Happy holidays!
Lee
lee.minardi
