Export data to Excel
edsaqueteAG5Q7
Message 1 of 10
edsaqueteAG5Q7
I'm trying to develop a command to extract data from the drawing and save it to a standard spreadsheet.
I need to define a directory to leave the default worksheet and after the open and update command save in the directory folder of the dwg file.
Another point is after getting the necessary data from the blocks, I need to define which column and line I will write in the worksheet.
In the spreadsheet there are more than one tab, is it possible to define which one I will use?
Replies (9)
Message 2 of 10
-didier-
Bonjour
The easiest way is to create a CSV file.
Do you need help to create that file with an LSP program ?
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 3 of 10
_gile
I agree with @-didier-  an in addition to what he said using a CSV is also much faster.
Anyway, if you absolutely want to follow the Excel file route, you can use these routines.
;; gc:WriteExcel
;; Writes in an Excel file
;; Arguments
;;   filename   : Excel file full path
;;   sheet      : name of the sheet (or nil for the current sheet)
;;   startRange : name of the start cell (or nil for "A1")
;;   dataList   : list of sublists containing the data (one sublist per row)
(defun gc:WriteExcel (filename sheet	startRange	  dataList /	    *error*  xlApp
	      wBook    save	sheets	 active	  start	   row	    col	     cells
	      n	       cell
 (vl-load-com)
 (defun *error* (msg)
   (and msg
 (/= msg "Function cancelled")
 (princ (strcat "\nError: " msg))
   (and wBook (vlax-invoke-method wBook 'Close :vlax-False))
   (and xlApp (vlax-invoke-method xlApp 'Quit))
   (and reg (vlax-release-object reg))
   (mapcar (function (lambda (obj) (and obj (vlax-release-object obj))))
    (list cell cells wBook xlApp)
   (gc)
 (setq xlapp (vlax-get-or-create-object "Excel.Application"))
 (if (findfile filename)
   (setq wBook	(vlax-invoke-method (vlax-get-property xlapp 'WorkBooks) 'Open filename)
  save	T
   (setq wBook (vlax-invoke-method (vlax-get-property xlapp 'WorkBooks) 'Add))
 (if sheet
   (progn
     (setq sheets (vlax-get-property xlApp 'Sheets))
     (vlax-for	s sheets
(if (= (strcase (vlax-get-property s 'Name)) (strcase sheet))
  (progn
    (vlax-invoke-method s 'Activate)
    (setq active T)
     (or active
  (vlax-put-property (vlax-invoke-method sheets 'Add) 'Name sheet)
 (if startRange
   (setq start	(gc:ColumnRow startRange)
  col	(car start)
  row	(cadr start)
   (setq col 1
  row 1
 (setq cells (vlax-get-property xlApp 'Cells))
 (or startRange (vlax-invoke-method cells 'Clear))
 (foreach sub dataList
   (setq n col)
   (foreach data sub
     (setq cell (vlax-variant-value (vlax-get-property cells 'Item row n)))
     (if (= (type data) 'STR)
(vlax-put-property cell 'NumberFormat "@")
     (vlax-put-property cell 'Value2 data)
     (setq n (1+ n))
   (setq row (1+ row))
 (vlax-invoke-method
   (vlax-get-property
     (vlax-get-property xlApp 'ActiveSheet)
     'Columns
   'AutoFit
 (if save
   (vlax-invoke-method wBook 'Save)
   (if	(and
  (< "11.0" (vlax-get-property xlapp "Version"))
  (= (strcase (vl-filename-extension filename) T) ".xlsx")
     (vlax-invoke-method wBook 'SaveAs filename 51 "" "" :vlax-false :vlax-false 1 1)
     (vlax-invoke-method wBook 'SaveAs filename -4143 "" "" :vlax-false :vlax-false 1 1)
 (*error* nil)
;; gc:ReadExcel
;; Returns a list of sublists containing the data (one sublist per row) from an Excel file
;; Retourne une liste de sous-listes contenant les données (une sous liste par rangée)
;; d'un fichier Excel
;; Arguments
;;   maxRange   : name of the cell where to stop reading,
;;                or "*" for the whole sheet, or nil or "" for the current range
(defun gc:ReadExcel (filename  sheet	 startRange	     maxRange  /	 *error*
	     xlApp     wBook wSheet	 startCell startCol  startRow  maxCell	 maxCol
	     maxRow    reg	 cells	   col	     row       data	 sub
	     lst
   (and msg
 (/= msg "Fonction annulée")
 (princ (strcat "\nErreur: " msg))
    (list reg cells wSheet wBook xlApp)
   (gc)
wBook (vlax-invoke-method (vlax-get-property xlApp 'WorkBooks) 'Open filename)
 (if sheet
   (vlax-for ws (vlax-get-property xlapp 'Sheets)
     (if (= (vlax-get-property ws 'Name) sheet)
(vlax-invoke-method (setq wSheet ws) 'Activate)
   (setq wSheet (vlax-get-property wBook 'ActiveSheet))
 (if startRange
   (setq startCell (gc:ColumnRow startRange)
  startCol  (car startCell)
  startRow  (cadr startCell)
   (setq startRange
   "A1"
  startCol 1
  startRow 1
 (if (and maxRange (setq maxCell (gc:ColumnRow maxRange)))
   (setq maxCol (1+ (car MaxCell))
  maxRow (1+ (cadr MaxCell))
   (setq reg	 (if (= maxRange "*")
	   (vlax-get-property wSheet 'UsedRange)
	   (vlax-get-property
	     (vlax-get-property wSheet 'Range startRange)
	     'CurrentRegion
  maxRow (+ (vlax-get-property reg 'Row)
	    (vlax-get-property (vlax-get-property reg 'Rows) 'Count)
  maxCol (+ (vlax-get-property reg 'Column)
	    (vlax-get-property (vlax-get-property reg 'Columns) 'Count)
row maxRow
 (while (< startRow row)
   (setq sub nil
  col maxCol
  row (1- row)
   (while (< startCol col)
     (setq col	(1- col)
    sub	(cons
	  (vlax-variant-value
	    (vlax-get-Property
	      (vlax-variant-value (vlax-get-property cells 'Item row col))
	      'Value2
	  sub
   (setq lst (cons sub lst))
 (*error* nil)
 lst
;; gc:ColumnRow -
;; Return a list containg the column and row indices
;; Arguments:
;;   Cell = Reference of the cell
;; Example: (gc:ColumnRow "IV987") -> (256 987)
(defun gc:ColumnRow (cell / col char row)
 (setq col "")
 (while (< 64 (ascii (setq char (strcase (substr cell 1 1)))) 91)
   (setq col  (strcat col char)
  cell (substr cell 2)
 (if (and (/= col "") (numberp (setq row (read Cell))))
   (list (gc:Alpha2Number col) row)
;; gc:Alpha2Number
;; Converts an alphabetic string into an integer
;; Function By: Gilles Chanteau from Marseille, France
;; Arguments
;;   str = string to convert
;; Example: (gc:Alpha2Number "BU") = 73
(defun gc:Alpha2Number (str / num)
 (if (= 0 (setq num (strlen str)))
   0
   (+ (* (- (ascii (strcase (substr str 1 1))) 64)
  (expt 26 (1- num))
      (gc:Alpha2Number (substr str 2))
;; gc:Number2Alpha
;; Converts an integer into an alphabetic string
;; Arguments: 1
;;   num = Nombre à convertir
;; Example: (gc:Number2Alpha 73) = "BU"
(defun gc:Number2Alpha (num / val)
 (if (< num 27)
   (chr (+ 64 num))
   (if	(= 0 (setq val (rem num 26)))
     (strcat (gc:Number2Alpha (1- (/ num 26))) "Z")
     (strcat (gc:Number2Alpha (/ num 26)) (chr (+ 64 val)))
Gilles Chanteau
GileCAD
GitHub
Message 4 of 10
Sea-Haven
Like you writing direct to excel is not that hard once you get the hang of it, I would like to say thanks for the couple of routines that you wrote Alpha2number and Number2alpha my excel would not work without them.
I started with getexcel.lsp and expanded on it and now have my own version of a excel program. I just use,
(if (not AH:getcell)(load "my excel library"))
this way it has all the defuns you want, with out putting all the excel code into the current lisp.
Like you I have
Getcell
PutCell
Getrange with smart input thanks to fixo
getallcells
openexist
openexcel-sheetname
addsheet "thanks to fixo"
closeexcel
isopenexcel
chkexcel-filename "is filename open"
newexcelname
setsheet
Sheetorder
I have not posted the code as you do need some experience programming in lisp and needs to be customised to suit the users data export requirements. But happy to discuss request.
There are a couple of others putting together excel Library functions. Such as denon@alxfunctions.com
Message 5 of 10
edsaqueteAG5Q7
_gile thanks for sending your code, I'll look into it to use the necessary commands for what I'm trying to do.
As for extracting in .csv that I already use, I want to automate in addition to .csv and extract directly to the standard execel worksheet in the columns and rows defined in lisp.
Message 6 of 10
edsaqueteAG5Q7
Sea-Haven and _gile
Follow step by step what I'm trying to do.
1-Open the model spreadsheet in a specific folder
2-Collect the block information (I already do this and save it in the .csv)
3-Identify which tab in the worksheet "Sheet1" or "Sheet2"
4-"Sheet1" fill in column "B" line "2" and "C" line "2" (repeat the same in "Sheet2'" depending on the information I'm going to extract from the blocks, this I can do)
5-Save the worksheet in the same folder where the dwg is saved (it will not be the same source folder.
Message 7 of 10
Sea-Haven
Can be done a question why save it twice ? Is it just so you have a backup ?
Make sheet 1 copyclip then paste to sheet2 would be easiest way to have 2 sheets the same writing 2 would be like a double handle.
1-Open the model spreadsheet in a specific folder yes need 2 things is it auto name like dwgname.xls, and location where to start search.
Final question how much about lisp do you know ? Did you give the code by Gile a go?
Message 8 of 10
edsaqueteAG5Q7
_gile
Thanks for sharing your code, I'm studying it to make my code along with other functions.
Message 9 of 10
edsaqueteAG5Q7
Sea Haven
I just posted models, I'm coding more complex spreadsheets.
My knowledge of lisp doesn't compare to yours, I make some codes to help with my work, but I still have a lot to learn.
Thank's for your time.
Message 10 of 10
Sea-Haven
Ok ask questions if you get stuck.
