Hello Everyone
I'm trying to customize the AutoCAD revcloud program with the hability to work with a personal app that calls to a preset layer, get the current scale and so on... it works but not as I wish.
(I have a revcloud app that works fine, but it's old and doesn't get the lastest upgrades of the autocad app)
First, the command line promp... it doesn't appear, no matter the value of the CLIPROMPTUPDATE value (see pictures below)
in the other hand, the revcloud registry value that defines the arc lenght starts with an *, so it can't be read from the VL-REGISTRY-READ function
I Need to show the command prompt while running the app and get the last arc value of the revcloud app
what am i missing? can you help me?
The customized app for evaluation
(DEFUN c:revcloud-cl (/ esca ARCL ARCLENGTH) (PRINC "\n Revcloud-cl") (uerr-def (LIST "undo" "clayer" "lunits" "CLIPROMPTUPDATE" "CLIPROMPTLINES" ) ) ;_ Personal App that stores the variables and original values to be restored at the end. You can eliminate this (SETVAR "lunits" 2)
;;; You can eliminate the following (IF (= nil (SETQ ARCL (VL-REGISTRY-READ (regpath-raiz) ;_ Personal Windows Registry Store Location "Arc Length Cloud" ) ) ) (SETQ ARCL (VL-REGISTRY-WRITE (regpath-raiz) ;_ Personal Windows Registry Store Location "Arc Length Cloud" "5" ) ) ) ;;; Until here
(SETQ esca (escala-sym nil)) ;_ Personal App that keep the working Scale (similar to Annotation Scale from AutoCAD). For evaluation you can change to 1 (LAYER "REVC") ;_ Personal app that change the Current Layer to the revision one (SETQ ARCLENGTH (* ESCA (DISTOF ARCL 2))) ;_Defines the ARCLENGTH in function of the Working Scale and the defined arc length (ARCL) at 1:1 scale (the final one). For evaluation you can change to .25 or 6 (imperial or metric) (SETVAR "REVCLOUDGRIPS" 1) ;_ Force this variable (SETVAR "REVCLOUDCREATEMODE" 2) ;_ Force to be Polygon Cloud (SETVAR "CLIPROMPTLINES" 5) (SETVAR "CLIPROMPTUPDATE" 1) ;_ <<< DOESN'T SEEMS TO WORK (INITCOMMANDVERSION 2) ;_ Force the app to Run the last version of RevCloud command
(COMMAND "REVCLOUD" "A" (- ARCLENGTH (* esca 0.25)) (+ ARCLENGTH (* esca 0.25)) ) ;_ Run the command and defines the Arclength (min and max) ;;; *** here the command makes the cloud (work) but i can't see the options in the command line!!! *** (WHILE (= (LOGAND 1 (GETVAR "cmdactive")) 1) (COMMAND pause) ) ;_ Pauses the program until the running command finish (SETQ maxarc (VL-REGISTRY-READ (STRCAT (VL-REGISTRY-PRODUCTKEY) "\\Variables") "*REVCLOUDMAXLENGTH" ) ) ;_ Try to Read the last value of the max arc lenght from the registry - DOESN'T WORK!!! (VL-REGISTRY-WRITE (regpath-raiz) ;_ Personal Windows Registry Store Location "Arc Length Cloud" (RTOS (- (/ maxarc esca) 0.25) 2 2) ;_ It returns the value of the arclength in function of the scale (opposite operation) ) ;_ Try to write the arc value in my personal location for future references (uerr-rest) ;_ Personal App that Restore the System Variables (PRINC) ;_Clean End )
Running the App with Clipromptupdate = 1
Running the App with Clipromptupdate = 0, no change
The original Revcloud Command showing the options (As I want it to be shown)
Windows Registry with the Arclength value (starts with *)
