Autorunning a LISP depening on string in file name?
basically, what I'm looking to do is add a routine I have for basic maintenance of a site plan drawing to the startup. every drawing is named with numbers and then siteplan as such:
######_SITEPLAN.dwg
Is there a way for me to check if SITEPLAN is in the file name, then run a specific command?
(setq dwgname (strcase (getvar "dwgname")))
(if (= dwgname "*SITEPLAN.DWG")
(C:AutoSiteScrub)
That's the best I've got. AutoSiteScrub is the name of the command I wish to run upon startup. I'm just not sure that the way I'm specifying the drawing name is correct.
Ranjit_Singh
Maybe add a startup function to your acaddoc.lsp file. Something like below
(defun-q spstartup ()
 (if (wcmatch (getvar 'dwgname) "*SITEPLAN.dwg")
  (print "This will print.")); after testing replace (print "This will print.") with (c:autositescrub)
(princ)) (setq s::startup (append s::startup spstartup))
Kent1Cooper
@KDAWG1213 wrote:
....  I'm just not sure that the way I'm specifying the drawing name is correct.
I wouldn't think it's necessary to define a startup function per se, but you should just be able to include that in acaddoc.lsp directly, and it will run at the opening of every drawing.  But you do need the one correction that @Ranjit_Singh included, namely that you need the (wcmatch) function rather than the (=) function when checking whether that wording is part of the drawing name.
Kent Cooper, AIA
scot-65
You may also try:
(vl-load-com)
(vl-string-search "SITEPLAN" (strcase (getvar 'DWGNAME)))
I do not remember if this function observes case-sensitivity...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
This works perfectly. Thank you!!
