select block and open bedit
I'm hoping someone can help me with this issue. I'm trying to create a lisp that will prompt the user to select a block then edit the block and change all the entities to layer 0 and bylayer.
Here is what i have. I've tried several different methods but i haven't had any luck so far. I'm obviously new to LISP and programming in general.
(defun c:fb (/ block bname)
(setq block (ssget'((0 . "INSERT"))))
(setq bname (cdr (assoc 2 (entget(ssname block)))))
(command "-bedit" bname )
(command "change" "all" "" "p" "la" "0" "")
(command "setbylayer" "all" "" "yes" "yes")
(princ)
Thanks in advance.
ВeekeeCZ
It ain't that bad...
  (setq block (ssget "_+.:E:S" '((0 . "INSERT"))))  ;; select single entity, for multiple selection its too slow anyway
  (setq bname (cdr (assoc 2 (entget(ssname block 0)))))  ;; index forgotten , 0 is the first
  (command "_.bclose" "_save")  ;; close the editor
  (princ)
Kent1Cooper
@Anonymous.fahrenkrug wrote:
.... I'm trying to create a lisp that will prompt the user to select a block then edit the block and change all the entities to layer 0 and bylayer. ....
There are routines out there to do just that, such as this one.  If you'd prefer to adjust yours to work right, you could probably steal elements from it, rather than use it instead of yours.
Kent Cooper, AIA
Dang it. I was so close! I just put WAY to much time into this simple lisp.
Thank you for the help BeeKeeCZ!!
I'll have to check out that site.
Thank you.
ВeekeeCZ
You're welcome!
If you're able to accept the fact that it was just a good learning lesson, that it worse it!
If you're able also accept the fact that your routine probably would not be the best one, then you can try enclosed routine(s)... which are so much faster!
- fix a single block
- fix all blocks in the drawing
- fix by sub-entity
Sweet! I need to learn how to make my lisps more like these!
