Need help getting a Lisp to work
Message 1 of 12
Hello, I am having a hard time getting this Lisp to run in autocad.It gives me a "too many arguments" error. It is supposed to create a legend based on the pointstyle name of the points. This is being modified to work with the pointstyle name of the cogo points, previously a tblnext was used on the blocks, and worked flawlessly.
any advice would be appreciated. Thanks.
(defun c:legend ()
(vl-load-com)
	(setq temperr *error*)				;store *error*
	(setq *error* trap1)				;re-assign *error*
(setq oldhigh (getvar "Highlight")
      oldsnap (getvar "Osmode")
      oldecho (getvar "Cmdecho")
      oldtext (getvar "Textstyle")
      oldlay  (getvar "clayer")
); gets variables to reset at the end of the routine
(c:pointSelection); select cogo pointstyle names, defun at end of file
(setvar "osmode" 0) ;turns off all snap in osnap
(setvar "clayer" "LEGEND")
(setvar "textstyle" "S80");
(setq lf 1)
(setq curh (cdr (assoc 40 (tblsearch "STYLE" (getvar "textstyle")))))
(setvar "cmdecho" 1)
(setq bbp (getpoint "\nPick start of legend: "))
(setq lfile (open "P:\\Lisp\\LEGEND.TXT" "r"))
(setq bllist nil)
(while
	(setq blockn (read-line lfile))
	(setq blockd (read-line lfile))
	(setq bllist (cons (list blockn blockd) bllist))
(close lfile)
(setq lfile (open "P:\\Lisp\\LEGEND.TXT" "a"))
(setq
	n (sslengtth styleList)
	cnt 1
	index 0)
(repeat n
   (setq bname (nth index styleList))
		(setq bdesc (cadr (assoc bname bllist)))
   (command-s "insert" bname
             (setq cbp (polar bbp (/ (* 270 PI) 180) (* cnt (/ lf 3))))
             lf
             0.0
   (if (= curh 0.0)
    (command-s "TEXT" "j" "ml"
             (polar cbp 0 (/ lf 1.6))
             (* lf 0.08)
             0.0
             (STRCAT "= " BDESC)
             0.0
             (STRCAT "= " BDESC)
	(setq cnt (1+ cnt)
		index (1+ index))
);end repeat
;;end of routine
	(close lfile)
	(setvar "Highlight" oldhigh)
	(setvar "Osmode" oldsnap)
	(setvar "Cmdecho" oldecho)
	(setvar "textstyle" oldtext)
	(setvar "clayer" oldlay); returns vars to orignal state before lisp
	(princ)
) ;end defun Legend
	(setq *error* temperr)				;restore *error*
	(defun trap1 (errmsg)					;define function
	;(command-s "u" "b")				;undo back
	(setvar "osmode" oldsnap)			;restore variables
	(setvar "highlight" oldhigh)
	(setvar "cmdecho" oldecho)
	(prompt "\nRe-Setting System Variables " temperr)	;inform user
(defun c:pointselection (/ pntSel index pntStyle pntName styleList)
(vl-load-com)
  (if (setq pntSel (ssget "X" '((0 . "AECC_COGO_POINT"))))
    (progn
      (repeat (setq index (sslength pntSel))
        (and (setq pntStyle (vlax-get (vlax-ename->vla-object (ssname pntSel (setq index (1- index)))) 'style))
             (setq pntName (vlax-get-property pntStyle 'name))
             (or (member pntName styleList)
                 (setq styleList (cons pntName styleList))
    )(princ)
Replies (11)
Message 2 of 12
Ranjit_Singh
prompt just takes one argument. You have an error in your *error*  function. It's a good habit to leave out the error function in development stages.
(prompt "\nRe-Setting System Variables " temperr); temperr is the extra argument
Did the routine work before adding the error function?
Message 3 of 12
ВeekeeCZ
a typo, sslengtth
Message 4 of 12
The routine worked before I modified it. Thanks for catching that.
Message 5 of 12
Thanks for catching that typo.
the lisp is still not performing, it errors out without message.
Message 6 of 12
I took out the error handling as suggested and got this error message
Command: LEGEND
Pick start of legend: ; error: bad argument type: lselsetp nil
Message 7 of 12
ВeekeeCZ
Unless you post something to test it on, I'm out.
dwg, txt, block.
And the original lisp may help as well.
Message 8 of 12
hmsilva
Command: LEGEND
Change
(sslength styleList)
to
(length styleList)
Hope this helps,
Henrique
Message 9 of 12
ВeekeeCZ
@hmsilva wrote:
Change
to
(length styleList)
Hope this helps,
Henrique
Hi Henrique, glad you came by and dropped something smart here! Merry Christmas to you and for the new year I hope that you do this little more often than this year, despite the fact that is harder not to. Cheers!
Message 10 of 12
@hmsilva wrote:
Command: LEGEND
Change
to
(length styleList)
Hope this helps,
Henrique
Thank you, this solved the problem of the lisp not running. I really appreciate the help here.
Message 11 of 12
hmsilva
Hello Beekee!
It has been a busy year and no spare time....
But I have given some help at the Português forums.
Merry Christmas to you too.
Cheers
Henrique
Message 12 of 12
hmsilva
You're welcome, aftermethod!
Glad I could help
Henrique
